VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective
Go to page: 1, 2  Next
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
rici007
Post02-03-2014, 13:42    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
The preheating light has come on for me several times, and the MFA (Multi Function Display) shows a message indicating an engine fault.
A scan using VCDS revealed that the sensor G235 is defective or malfunctioning intermittently.
I would like to replace the fuel pump, but I have read several times that there are three different types or that three fuel pumps are installed in the car.
Where am I supposed to know which donor is defective now?
A visit to Volkswagen didn't help either; the employee said that the sensor G235 is installed three times.
- Before turbochargers.
- Before DPF
- After the DPF.
The prices are expected to be around €145-€150.
Here is the excerpt from VCDS:
2 Fehlercodes gefunden:
001348 - Geber 1 fĂźr Abgastemperatur (G235)
P0544 - 000 - elektrischer Fehler - Sporadisch
Freeze Frame:
Fehlerstatus: 00100000
Fehlerpriorität: 2
Fehlerhäufigkeit: 4
Verlernzähler: 255
Kilometerstand: 158487 km
Zeitangabe: 0
Datum: 2058.14.16
Zeit: 19:24:10
Freeze Frame:
Drehzahl: 1449 /min
Geschwindigkeit: 44.0 km/h
Spannung: 14.06 V
Temperatur: 62.1°C
Temperatur: 930.0°C
Temperatur: 108.0°C
Temperatur: 78.0°C
P0544 - 000 - elektrischer Fehler - Warnleuchte EIN
Freeze Frame:
Fehlerstatus: 11100000
Fehlerpriorität: 2
Fehlerhäufigkeit: 2
Verlernzähler: 255
Zeitangabe: 0
Datum: 2058.14.16
Zeit: 19:24:15
Freeze Frame:
Drehzahl: 1541 /min
Geschwindigkeit: 32.0 km/h
Spannung: 13.91 V
Temperatur: 69.3°C
Temperatur: 930.0°C
Temperatur: 120.0°C
Temperatur: 90.0°C
Readiness: 0 0 0 0 0
Translated on 16-07-2026, 21:48.
mullemaus
Post02-03-2014, 15:46    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
If I were to think logically, I would assume:
Donor 1 = after turbocharger.
Sensor 2 = upstream of the DPF.
Donor 3 = after DPF.
The values would also confirm this:
Temperature: 930.0°C
The shutdown temperature at that point varies depending on the software version and is typically between 820-850°C.
Devices 2 and 3 do not achieve such values icon_wink.gif.
Are you sure this car is a standard production model?
Translated on 16-07-2026, 21:50.
Post02-03-2014, 17:07    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
icon_smile_thumb_up.gif icon_wink.gif The icon_lol.gif can find this information using the VIN and by searching via the SDC code, so it shouldn't be a problem.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 16-07-2026, 21:52.
Post02-03-2014, 19:25    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Ihr meint sicher beide VOR Abgasturbolader, welcher Unterschied sollte denn eurer Meinung nach zwischen "nach Abgasturbolader" und "vor DPF" sein? icon_cool.gif
It is quite certain that the described sensor is screwed into the side of the exhaust housing of the turbocharger.
Stecker dieses Gebers trennen und entstehende Fehlermeldung prĂźfen ergibt Bingo oder Bull****. icon_wink.gif
Translated on 16-07-2026, 21:53.
mullemaus
Post02-03-2014, 19:29    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Ihr meint sicher beide VOR Abgasturbolader, welcher Unterschied sollte denn eurer Meinung nach zwischen 'nach Abgasturbolader' und 'vor DPF' sein? icon_cool.gif
Best regards, Rainer
The sender is located behind in front of the turbocharger, but is often incorrectly referred to as being 'in front of it'.
Before the DPF, it's located at the inlet; after that, it's behind the DPF.
His car actually has 3 distributors icon_wink.gif.
mullemaus
Post02-03-2014, 19:31    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Here in the redacted bid, you can see it.
Donor 1 is located behind, between the exhaust manifold and in front of the turbocharger (exhaust outlet), while the others are located before and after the DPF icon_wink.gif.
Translated on 16-07-2026, 21:54.
Post03-03-2014, 18:24    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
In the 170 hp PD-TDIs from Audi, it is located at the air intake.
Translated on 16-07-2026, 21:55.
Post03-03-2014, 20:22    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
If the image is somewhat realistic, the sender should be pointing towards the passenger seat.
Whether I'll catch it with a flashlight, mirror, and digital camera...
EDIT: Oh crap... CBBB... I have a BMR and otherwise only CBAB in the area.
EDIT2: haha icon_smile.gif They all have it icon_smile.gif.
Translated on 16-07-2026, 21:56.
rici007
Post03-03-2014, 21:40    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
hello,
Thank you for the answers.
The car is 100% in its original condition.
As I understand it, this refers to sensor 1 on the turbocharger.
Can I be absolutely certain about this using my VCDS device?
Translated on 16-07-2026, 21:57.
Post03-03-2014, 21:50    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Hi.
930°C sounds like the upper limit of a measuring scale.
I've never seen temperatures above 810°C at the BMR; it's more like around 800°C.
Possibly, you might get lucky, and it will also display a cold reading of 930°C... in which case, it would be very easy to identify the culprit.
Top left corner, that must be it.
The CBAB definitely has a BV43 fitting – I installed one just two weeks ago.
The CBBB has a... hmmph, sorry, but it also has a Borg-Warner.
 File size:  33.75 KB
 Viewed:  4322 times
Translated on 16-07-2026, 21:58.
Post03-03-2014, 21:54    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Kann ich das denn mit meinem VCDS zu 100% festlegen?
You have read the G235 code. The dealer is searching for "G235" in AKTE and correctly identifies sensor 1. What's so difficult about that? Order it, replace it, and continue checking icon_wink.gif.
Translated on 16-07-2026, 21:59.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
dieselschrauber likes this.
Post03-03-2014, 21:55    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
The picture is nonsense. The exhaust temperature sensor (G235) is located directly in front of the turbine housing. When installing it, make sure it doesn't hit anything.
reflexsilber met.
Translated on 16-07-2026, 22:00.
rici007
Post03-03-2014, 22:01    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
@autoservice
I don't think you understand me.
I've now been to two different Volkswagen parts suppliers.
If he enters 'G235', he will have three different sensors to choose from.
If it were that simple, I wouldn't have started a thread about it.
@dieselmartin
Do you perhaps know what the product code is?
Should I just let the whole thing be for now, since the error only occurs sporadically?
Translated on 16-07-2026, 22:01.
Post03-03-2014, 22:04    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
Just take the 03L906088BS... that's what the internet says icon_smile.gif.
http://workshop-manuals.com/audi/a3_mk2/power_unit/4-cylinder_tdi_engine_%282.0_ltr._4-valve_common_rail%29_mechanics/exhaust_system/exhaust_gas_temperature_control_%28vehicles_with_engine_codes_cbaa_cbab_cbbb%29/removing_and_installing_exhaust_gas_temperature_sender1g235/
Was it that difficult?
But I'll tell you right away, it's incredibly cramped back there behind the turbocharger.
It's probably easiest to approach it from below.
Translated on 16-07-2026, 22:02.
mullemaus
Post03-03-2014, 22:11    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
The picture is nonsense. The exhaust temperature sensor (G235) is located directly in front of the turbine housing. When installing it, make sure that it doesn't touch anything.
From the donor to the exhaust, there are only 2...3 cm, and only the exhaust turbine wheel is in between. icon_wink.gif
 File size:  187.18 KB
 Viewed:  53305 times
Translated on 16-07-2026, 22:03.
Post04-03-2014, 11:25    Subject: VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G235) defective Quote
As you can see in the last picture, the fuel injector, as one might expect, is located BEFORE the turbocharger.
What significant differences should donors measure before the DPF and after the catalytic converter, specifically a difference of 5°C?
RedR32 hat Recht, das von mullemaus verlinkte Bild, vermutlich aus dem Teilekatalog ist wie so viele andere auch (da oft nicht zum jeweiligen Modell passend und nur schematisch) fĂźr die Tonne... icon_razz.gif
Der Link von dieselmartin kommt der Realität wesentlich näher. Das angehangene Bild im vorhergehende Posting vom mullemaus isrt eindeutig. icon_thanks.gif
@mullemaus:
However, those few centimeters are crucial because the exhaust turbine experiences a significant drop in temperature due to the expansion of the exhaust gases. This results in a reading on the sensor before the Diesel Particulate Filter (DPF). icon_wink.gif
Translated on 16-07-2026, 22:04.
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Unlock XDS on a Passat B7 4motion 125kW (MJ12-kw22) Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3C 125kW not pulling properly Diesel Engine Technology
No new posts 2.0 TDI BKD: AGR Valve Problem? Diesel Engine Technology
No new posts Replace exhaust sensor 1 (G235) in the 9N3 BMS Diesel Engine Technology
