Passat: Engine Stalling, Relay Problems - Fix!
sebv6
2000 Volkswagen Passat Consumption
Post23-05-2014, 19:49    Subject: Passat: Engine Stalling, Relay Problems - Fix! Quote
Hello, I recently received a 2004 VW Passat 3BG with the AVF TDI engine. The symptom is that it suddenly stalls, and the check engine light has been on intermittently. The fuel pump relay has already been replaced.
Detected: Various relay failures including glow plug relay, turbocharger boost control valve relay, EGR valve relay, and fuel pump relays.
Deleted, test drive, found: Mass airflow sensor completely out of whack, then it shut off and wouldn't start.
"I unplugged the mass airflow sensor (MAF) connector from my old car, and it started up again! I then realized that he had also unplugged the intake manifold pressure sensor connector."
Einbau Neuteile original VW. LMM und Saugrohrdrucksensor. Running great! / Perfect!
Customer picked up the car, 3 days later: Emergency mode, no power.
I spent days searching for a problem: No errors appeared, it ran perfectly, I did 50km of test drives, but couldn't find anything wrong. (It was summer, and the car temperature inside reached 30 degrees Celsius).
Heute morgen Zündung an und gleich Fehlerlampe an. Wieder diese Relaisfehler vom Anfang. Auch keine Leistung! Approximately 25 horsepower.
Dann das Kraftstoffpumpenrelais und NR 202 für Glühkerzen gezogen. Jetzt läuft der Wagen trotz der fehlenden Relais! Die Kraftstoffpumpe läuft sauber an! AbeIt's currently in emergency mode.
Hmm...
Does this device also have the 167 relay?
Passat TDI PD AWX 12/2000
Translated on 10-08-2026, 8:37.
Post23-05-2014, 20:18    Subject: Passat: Engine Stalling, Relay Problems - Fix! Quote
What exactly is stored in the error memory?
Have you checked the wiring harness yet?
Translated on 10-08-2026, 8:39.
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Camshaft Bolt Service: PD Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3bg AVF engine occasionally stalls Diesel Engine Technology
No new posts Passat 1996: Engine Stalling - Troubleshooting Diesel Engine Technology
No new posts VW Passat: Intermittent Limp Mode Issue Diesel Engine Technology
No new posts Passat TDI: Engine Stalling After Cold Start On-Board Diagnostics (OBD)
