Torque hum at AHF / BLS
Go to page: 1, 2, 3  Next
vwSchrauber
Post01-10-2012, 11:36    Subject: Torque hum at AHF / BLS Quote
I recently purchased a Toledo AHF as my winter car.
Once I have the necessary equipment at home, I have optimized the software a bit for efficiency, meaning I have also increased the torque a bit in the lower speed range.
Although I increased the amount by 2000 1/min while only increasing it by 5mg, I experienced an extremely unpleasant torque noise in this speed range. This feels like it's back to the days when aftermarket tuning boxes were common on these engines, and people would push them to their limits.
5mg represents approximately 25Nm more, and engines with identical specifications can easily handle this without the associated noise in the drivetrain.
Two-mass swing behaves normally (no shaking in the LL, quantity deviations constant), where else can I look for an error?
Karma: +807 / -0   Thank you, like it!
Post01-10-2012, 12:54    Subject: Torque hum at AHF / BLS Quote
Motor bearing.
Best regards, Rainer
vwSchrauber
Post01-10-2012, 13:36    Subject: Torque hum at AHF / BLS Quote
Thank you, I will watch it tonight.
Detail at the edge: at the motor mount for the timing belt, the screws were loose... it made a lot of noise...
vwSchrauber
Post02-10-2012, 11:26    Subject: Torque hum at AHF / BLS Quote
Then I checked again yesterday, and indeed - the rubber buffer on the back of the torque arm is hanging loose...
EDIT: The clutch has been swapped, and the humming is gone. Unfortunately, I still have an unpleasant vibration in the drivetrain, which I suspect is in the left drive shaft joint. That definitely has potential...
Post15-10-2012, 14:12    Subject: Torque hum at AHF / BLS Quote
HI
I also had a humming noise with the standard BLS and I was also suspecting the motor mounts.
/viewtopic.php?t=25124&highlight=torque
How are the two semi-bearings in the axle body "mounted"?
Secured with a screw?
Or pressed, so simply difficult to change with a roller?
Visually, there's nothing to criticize.
vwSchrauber
Post17-10-2012, 15:54    Subject: Torque hum at AHF / BLS Quote
It seems like the shaking is getting worse and worse. Currently, I'm at a series dose (43mg @ 2000 1/min) and the injection starts 2 degrees from the OT (Original Position), and the car is shaking so much that the phone in the center console (under the ashtray) is practically jumping.
However, this is not always the case, sometimes it is better, sometimes it is worse.
...such a violent shaking shouldn't really come from the drivetrain.
How do you mean? the suspension components that connect the front axle to the frame or the load-bearing parts of the chassis?
Post17-10-2012, 16:07    Subject: Torque hum at AHF / BLS Quote
EDIT: The driveshaft was swapped, and the noise is gone. Unfortunately, I still have an unpleasant vibration in the drivetrain, which I'm attributing to the left driveshaft bearing. That definitely has potential...
Possibly, one of the internal joints is also stuck.
Post17-10-2012, 20:15    Subject: Torque hum at AHF / BLS Quote
How do you mean? the mounts that connect the front axle to the frame or the load-bearing parts of the chassis?
I am referring to this warehouse:
/download.php?id=5528
It also consists of two halves - an upper and a lower one.
Can they be replaced if the central screw is out, or are they really pressed in?
vwSchrauber
Post20-11-2012, 13:04    Subject: Torque hum at AHF / BLS Quote
Finally got him on stage yesterday, looks completely different than in the Toledo...
Now, I suspect that the problem is more likely due to the drive shaft bearings, as both show significant play. Exchange will bring clarity icon_smile.gif
 Pendelstütze
Pendelstütze
 File name:  IMG_0894_v.jpg
 File size:  691.38 KB
 Downloaded:  1291 times
Post20-11-2012, 13:42    Subject: Torque hum at AHF / BLS Quote
Yeah, this is the Golf IV version of the shock absorber.
Post20-02-2013, 15:35    Subject: Torque hum at AHF / BLS Quote
Is there anything new?
Our golf (MJ08, still with the old version of the steering column) is now making quite a bit of noise.
I'm afraid of the drilling and filling process.
vwSchrauber
Post26-02-2013, 12:50    Subject: Torque hum at AHF / BLS Quote
No, not yet. Once winter is over, I need to replace the ZMS and drive shafts... Currently, they are at the mechanic's shop, where a blind and deaf old woman drove in who didn't know any priority rules icon_evil.gif
Post26-02-2013, 13:51    Subject: Torque hum at AHF / BLS Quote
is currently at the blacksmith's.
LOL, ours is finished again (after a crash).
Then I'm hoping for an update soon.
Post26-02-2013, 15:52    Subject: Torque hum at AHF / BLS Quote
vwSchrauber wrote:
No, not yet. Once winter is over, I need to replace the ZMS and drive shafts... Currently, they are at the mechanic's shop, where a blind and deaf grandmother drove in, who didn't know any priority rules icon_evil.gif
vwSchrauber
Post01-03-2013, 12:48    Subject: Torque hum at AHF / BLS Quote
might be - but you must already be familiar with priority rules? icon_lol.gif
Post15-11-2013, 9:27    Subject: Torque hum at AHF / BLS Quote
I don't understand it.
Whenever it's cold, our BLS makes a humming sound, similar to a pig, in the range of up to 1400.
Is the weather warm (summer) or can one imagine a certain warming of the entire car due to radiation from the engine, is it less or gone.
Unfortunately, the ZR change (motor bearing removal) coincided perfectly with the weather change, so I can't attribute it to any specific event.
However, since I was already lamenting last autumn, it is probably quite certain about the temperature.
Let's brainstorm and hear your ideas on what I could test first to find the root cause.
