Excessive soot buildup, reduced performance, and moderate gas response
Go to page: 1, 2  Next
Frickus
Post01-12-2014, 20:49    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Hello, as described above, I've been having issues with my Audi A4 2.0 TDI B7 since yesterday. When starting, I can press the accelerator pedal fully, and initially, nothing happens until a cloud of black smoke appears, and then the engine starts to respond. The same thing happens when I'm driving at 100 km/h in 6th gear. "Someone who wants to maintain a certain speed and then accelerate again."
There were two errors stored in the memory:
00257/000 P0101 Mass Air Flow Sensor - Implausible Signal.
00665/000 P0299 - Boost pressure control - Limit below threshold.
Both errors were intermittent and could be cleared, and the MKL (Malfunction Indicator Lamp) was not illuminated. Subsequently, I quickly borrowed and installed an LMM (Mass Air Flow Sensor) from a friend, but that didn't help either. After that, I took the car for a test drive, and I suspect the EGR valve is the culprit. Can anyone confirm this?
Here's what came out of the log:
Monday, December 1, 2014, 18:15:50:38025
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 12.12.3.0
Data as of: 20140904
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 01: Engine Control Module (03G 906 016 JD)
18:15:40
3.8 mg/H Injection volume
7.1°KW Operating time (target value)
882 /min Motor speed (G28))
0.0% Accelerator Pedal Position
295.0 mg/H - Exhaust Gas Recirculation (Target Value)
285.0 mg/H Exhaust Gas Recirculation (Actual Value)
99.6% Exhaust Gas Recirculation (EGR) control.
0.0 km/h Speed (actual value)
0.0% Position (Target) EGR Valve.
0.0% Position (Actual) AGR Valve
Monday, December 1, 2014, 18:22:56:38025
18:22:54
1953 /min Motor speed (G28))
1020.0 mg/H - Exhaust Gas Recirculation (Target Value)
315.0 mg/H Exhaust Gas Recirculation (Actual Value)
2346.0 mbar - Boost pressure (target value)
1275.0 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:34:15:38025
18:34:12
2562 /min Motor speed (G28))
330.0 mg/H - Exhaust Gas Recirculation (Target Value)
485.0 mg/H Exhaust Gas Recirculation (Actual Value)
1040.4 mbar - Target boost pressure.
1295.4 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:34:35:38025
18:34:32
3171 /min Motor speed (G28))
575.0 mg/H - Exhaust Gas Recirculation (Target Value)
590.0 mg/H - Exhaust Gas Recirculation (Actual Value)
1050.6 mbar - Boost pressure (target value)
2060.4 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:36:05:38025
18:36:03
3213 /min Motor speed (G28))
100.0% Accelerator Pedal Position.
1050.0 mg/H - Exhaust Gas Recirculation (Target Value)
460.0 mg/H Exhaust Gas Recirculation (Actual Value)
2315.4 mbar - Boost pressure (target value)
1836.0 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:36:34:38025
18:36:32
1575 /min Motor speed (G28))
310.0 mg/H - Exhaust Gas Recirculation (Actual Value)
1030.2 mbar - Boost pressure (target value)
1173.0 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 6:36:54:38025 PM.
18:36:53
2121 /min Motor speed (G28))
1045.0 mg/H - Exhaust Gas Recirculation (Target Value)
435.0 mg/H - Exhaust Gas Recirculation (Actual Value)
1642.2 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:37:35:38025
18:37:31
1491 /min Motor speed (G28))
345.0 mg/H - Exhaust Gas Recirculation (Target Value)
415.0 mg/H - Exhaust Gas Recirculation (Actual Value)
1071.0 mbar - Boost pressure (actual value)
Monday, December 1, 2014, 18:38:46:38025
18:38:41
2835 /min Motor speed (G28))
385.0 mg/H - Exhaust gas recirculation (target value)
495.0 mg/H - Exhaust Gas Recirculation (Actual Value)
I would be very grateful for any helpful answers. Best regards, Frickus.
LOG-01-021-03E-116.CSV
 File name:  LOG-01-021-03E-116.CSV
 File size:  11.7 KB
 Downloaded:  479 times
Post01-12-2014, 22:03    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
First of all, you should check if the VTG adjustment is moving, as that should only take about 5 minutes.
In the idle state, the linkage should move approximately 10mm towards the vacuum diaphragm.
The easiest way to do this is by alternately connecting and disconnecting the vacuum hose from the VTG valve.
If it doesn't engage, check if there is a vacuum present. Check if there is a vacuum, and if not, check the VTG (vacuum train control) system. Verify the VTG is functioning correctly and inspect the vacuum reservoir for leaks.
Also, also check the vacuum system for leaks.
I would only continue investigating the air supply once I'm certain that these errors can be ruled out.
A cleaning cloth or something similar may have accidentally gotten into the intake manifold (air filter) icon_question.gif.
Frickus
Post01-12-2014, 22:19    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
"Thank you for the tips, I will definitely do those first thing tomorrow. No, that's unlikely, because the problem appeared suddenly on the highway, after I had already driven 650 km on Saturday and another 200 km on Sunday." However, I still opened the air filter and checked it, just to be sure, but there was nothing clogged or blocked.
Okay, so my first step will be to check the VTG linkage and the pressure hoses. If that doesn't help, I'll remove the AGR valve and inspect it.
Post02-12-2014, 7:34    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Autoservice wrote:
First of all, you should check if the VTG adjustment is moving, because that only takes 5 minutes.
For the sake of completeness, you can certainly do this here.
But even if the VTG (vehicle traction generator) were "dead," it shouldn't cause excessive black smoke, as long as the rest of the hardware is functioning properly.
I suspect there's a small to medium-sized leak in the intercooler system, which is causing some of the increasing boost pressure to be lost -> that's why the engine isn't pulling well at low RPMs.
Since diesel fuel is injected into the escaping air mass, it produces soot (unless the soot limit is calculated based on the boost pressure, which, as far as I know, is more of an exception than the rule).
Only when the engine reaches higher RPMs can the turbocharger pressure increase to its normal levels -> the engine starts to accelerate, but it still produces excessive soot.
Karma: +1344 / -0   Thank you, like it!
Post02-12-2014, 9:49    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
I'm surprised by the high EGR target values and the full EGR activation when accelerating (I interpret the high LD target values as a pressed accelerator pedal). The AGR actual value lags behind, just like the boost pressure, then it increases, and the boost pressure stabilizes.
Shouldn't the AGR (Abgasrückführung) value be reduced and the LM (Leerlaufdrehzahl) increased during acceleration?
Post02-12-2014, 10:04    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Herbert wrote:
Shouldn't the EGR value be reduced during acceleration, and the LM (lambda) increased?
For the EDC15 system, the N75-TV value is generally low at full throttle, but this doesn't necessarily have to be the case for other EDC systems.
Post02-12-2014, 10:13    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Do you mean that what is listed in the log as "AGR Desired/Actual" actually represents the air mass?
Post02-12-2014, 10:32    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Herbert wrote:
You mean that what is listed in the log as "AGR Desired/Actual" is actually the air mass?
Yes.
While I can only see the log as a collection of numbers again, for example, in the post by TS:
18:22:54
2346.0 mbar boost pressure (target value).
1020.0 mg/H Exhaust Gas Recirculation (Target Value)
It only makes sense together if the target AGR value is represented as a luminance value.
Post02-12-2014, 10:55    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
The log can be read. If not using a dedicated tool like Scope, you can import the data into Excel as a .txt file and then specify the delimiters.
If LM and LD are significantly lagging behind the target and then suddenly increase, it suggests an issue with the LD regulation, which could indicate problems with the VTG (Variable Transmission Gear).
Post02-12-2014, 11:25    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Herbert wrote:
If LM and LD are initially significantly below the target and then increase, it suggests the LD regulation is at play, which could indicate VTG issues.
1. The LuMa-Soll value at WOT (Wide Open Throttle) is usually not a realistically achievable value without full LD (Load Dump).
2. If the problem were only related to the VTG hardware, the vehicle shouldn't produce excessive smoke – unless it has been poorly modified.
Frickus
Post02-12-2014, 17:35    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
I've started working on the intercooler system, and when oil started leaking out of the hose between the intercooler and the throttle body, I thought I'd remove the throttle body and take a look at what's causing the problem.
"Everything was completely carbonized, so the EGR valve and intake manifold were also removed at the same time." It doesn't look perfect, but it's very authentic.
 File name:  image.jpg
 File size:  1.15 MB
 Downloaded:  2117 times
 File size:  2.85 MB
 Downloaded:  574 times
 File size:  1.55 MB
 Downloaded:  703 times
 File size:  2.23 MB
 Downloaded:  541 times
 File size:  2.12 MB
 Downloaded:  594 times
 File size:  2 MB
 Downloaded:  557 times
 File size:  2.33 MB
 Downloaded:  552 times
Post02-12-2014, 20:57    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Replace the AGR valve with a replacement part from the aftermarket.
The turbocharger pressure regulation is faulty. Engine control unit: stock or tuned?
Mileage? With over 200,000 km on your car, and if it's your own vehicle, you can order a new throttle body (a readily available replacement part) at the same time.
Frickus
Post02-12-2014, 22:58    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
Hi Rainer, the engine control unit is original. It now has 195,000 km on it and it's my own car. After a thorough cleaning of the throttle body, EGR valve, and intake manifold with turpentine, I've found the problem: the EGR valve is the culprit. The valve has failed and is no longer working or sealing properly. I've managed to clean the rest of the components. But still, thank you in advance to everyone for your thoughts and suggestions. I will let you know if it was indeed the error.
 File size:  1.62 MB
 Viewed:  648 times
 File size:  2.01 MB
 Downloaded:  519 times
 File size:  1.67 MB
 Downloaded:  485 times
 File size:  1.33 MB
 Downloaded:  532 times
 File size:  2.18 MB
 Downloaded:  445 times
Post03-12-2014, 9:54    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
...one more thing: How on earth can a BRE motor produce soot? Here, a closed DPF is installed as standard. icon_question.gif
There are then two possibilities:
- defective (broken, etc.), with the possibility that parts could block the exhaust.
- removed, which would not only be pointless but also prohibited.
Frickus
Post03-12-2014, 10:28    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
"So, he's definitely not removed, because it's still inside. According to the previous owner, the DPF was already replaced, and Audi confirmed this, as it was done there. Is it broken? It might be, but my guess is that the broken throttle valve in the EGR system allowed too much exhaust gas to enter the combustion chamber, and the DPF was simply "overwhelmed"." If the new EGR valve arrives tomorrow or on Friday, I will report back whether the excessive soot has stopped. If not, the troubleshooting process will continue.
Post03-12-2014, 13:28    Subject: Excessive soot buildup, reduced performance, and moderate gas response Quote
This type of DPF cannot be "overloaded." If too much soot accumulates, it will become clogged and fail. Then it's finished.
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts Engine Noise in Car: A6 4B (1999) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BMM: Power Loss, Soot & DPF Issues Diesel Engine Technology
No new posts 2.0 TDI (CR) Engine Code CBAB - No Power + Soot Formation Diesel Engine Technology
No new posts Tuning Box: Reduce Soot & Improve Performance Diesel Engine Technology
No new posts Performance degradation Diesel Engine Technology
