OBD Engine Control Unit: Meaning & Explanation
atlantic
Karma: +1 / -1   Thank you, like it!
Post21-05-2015, 14:16    Subject: OBD Engine Control Unit: Meaning & Explanation Quote
Unfortunately, I haven't found anything yet that would answer my question.
When you open a diagnostic session with an engine control unit (this is certainly true for KW1281 and KWP2000), you receive even more information about the control unit number.
The data looks like this:
Code:
028 906 021 GH 1.9l R4 EDC  (G) xx (S/A) G  1444
was das meiste bedeutet ist für mich ersichtlich:
028 906 021 GH 1.9l R4   EDC  (G)  xx  (S/A)G  1444
VAG Teilenummer   |       |    |    |     |      |
                Motor     |    |    |     |      |
              Steuergerätetyp  |    |     |      |
                              GRA   |     |      |
                                     Getriebe    |
                                            VAG Software, nicht Bosch SW
But now, the "xx"... those are still three big question marks for me.
Most of the time, it shows "00". Now I have an engine control unit with "30" - a 028906021GH and a 028906021GT, where the value at position "42" is different.
Can someone give me a breakdown of that?
Thank you and best regards.
Max
Translated on 26-08-2026, 15:24.
Wiesel
Post21-05-2015, 14:29    Subject: OBD Engine Control Unit: Meaning & Explanation Quote
The control units have different adaptation channels on the top.
or adapted to the lower stop.
Micha
Translated on 26-08-2026, 15:26.
atlantic
Post21-05-2015, 15:40    Subject: OBD Engine Control Unit: Meaning & Explanation Quote
Wow, really.
I still don't understand how it works. I just tried it with a 028906021GG. If you set channel 01 to maximum, it displays "10", but channel 02 doesn't display "20", and if you set channel 03 to maximum, it displays "40".
Does anyone know anything about this?
Max.
Wiesel
Post21-05-2015, 16:57    Subject: OBD Engine Control Unit: Meaning & Explanation Quote
The control units are not necessarily the same in that case.
Try each channel on the respective control unit (one channel at a time).
and take breaks for refreshments) and write down the results.
(Tip: binary icon_wink.gif)
It provides more insight than the fact that adaptation mechanisms are already at their limit.
Perhaps the whole thing was originally intended to allow workshops to operate with simple means.
We could see that significant modifications had been made to the adaptation channels.
Translated on 26-08-2026, 15:28.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit (ECU) Numbers: Meaning & Explanation Diesel Engine Technology
No new posts Alarm Source Meaning A8 4E On-Board Diagnostics (OBD)
No new posts MWB 3/AGR: Meaning of Duty Cycle Ratio On-Board Diagnostics (OBD)
No new posts TDI Injectors: Meaning & Function (AVF) On-Board Diagnostics (OBD)
