A6 4F 2.7 TDI: Idle Speed Modification
olli
Karma: +46 / -0   Thank you, like it!
Post19-08-2015, 20:57    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
Although the six-cylinder engine should run very smoothly, I have the impression that the idle speed is a little too high (770 RPM).
Can this engine control unit be...?
Address 01: Engine Control Unit (CAN)
Label file: DRV\059-907-401-CAN.clb
Part number SW: 4F7 910 401 K, HW: 4F0 907 401 E.
Component: 2.7 TDI EDC17G000SG, part number 0090.
Revision: 16H14--- Serial number:
Encoding: 010D002C18070128
Operating number: WSC 33103 136 175301.
VCID: 2B5294108A904379EBD-807E
Should I still adjust the idle speed?
Best regards from Berlin.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 30-09-2026, 2:39.
Post19-08-2015, 21:40    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
Many TDI engine control units should allow modification of the idle speed through adjustment. I haven't tested this on newer engines, simply because there was no need to do so.
Translated on 30-09-2026, 2:41.
olli
Post19-08-2015, 22:48    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
I tried..., but channel 2 in the MSG is displayed as 'not available', which is why I'm asking. I also looked in the label file, but it's a .clb file, not a .lbl file.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 30-09-2026, 2:42.
Post19-08-2015, 22:49    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
Have you already tried logging in with "12233" or whatever is displayed in the tooltip?
olli
Post19-08-2015, 22:51    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
dieselschrauber wrote:
Have you tried logging in with 12233 or whatever is in the tooltip (the little pop-up box)?
Hmm, of course not... I'll do it tomorrow; I was focused on the technical article and assumed no login would be required.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 30-09-2026, 2:43.
olli
Post20-08-2015, 21:55    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
Okay, so I tried logging in again today; Channel 2 is not available. I then navigated through the channels a bit further, and on Channel 6, a speed display appeared in the upper left corner. The value range for this channel is not documented; however, by reducing the value from the original 20 to 5, I was able to reduce the idle speed to the point where the vibration of the gear lever, which has sometimes been annoying me, has almost completely disappeared.
olli
A6 CANA/JME /
Ex-A6 AEL
Translated on 30-09-2026, 2:44.
Post23-08-2015, 20:08    Subject: A6 4F 2.7 TDI: Idle Speed Modification Quote
Great, thanks for the feedback!
No new posts 2.7TDI Kraftstoffdruck zu hoch Diesel Engine Technology
No new posts A5 2.7 TDI - Poor performance/acceleration, possible caus... Diesel Engine Technology
No new posts Frage zur Steuerung AGR Kühler Audi 2,7TDI Diesel Engine Technology
