RCD310: Downgrade from RNS315 (VW)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
simlesc
Post25-09-2015, 23:11    Subject: RCD310: Downgrade from RNS315 (VW) Quote
I would like to replace the installed RNS315 with an RCD310 because the map updates are ridiculously expensive. I can currently sell the RNS315 easily, and then I'll have money left over for a portable navigation device.
"To continue using the FSE (Freisprecheinrichtung), I would like to install a compatible module. Which ones are suitable? I've at least found out that the D-version (premium FSE with Wi-Fi) doesn't work. Since I don't need rSAP, I don't need to run an antenna cable, right? The existing cable doesn't connect to the RNS (radio navigation system) anyway, but only to the phone holder, if I'm understanding correctly?"
SL
Translated on 02-10-2026, 6:28.
turrican944
Post06-10-2015, 13:04    Subject: RCD310: Downgrade from RNS315 (VW) Quote
Hi.
I'm not sure which ones fit.
If you don't choose a car with the Rsap option (which also doesn't include Wi-Fi), you don't need to install an antenna cable. Do you have the larger MFA display in your car so you can also use the phone interface? The phone interface cannot be used through the RCD310.
http://www.carsystems.pl/volkswagen,c1.html
"There are plenty available there. If you have an MFA+ display, you can get one that doesn't require an MFL and then control it via the MFA display. Alternatively, you can also install an RCD510 and use it to control the FSE."
Octavia 1Z2.0 TDI 4x4 2008
Porsche 944S3 1986
Translated on 02-10-2026, 6:30.
Back to top Profile PM Email
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
