Hi.
I'm not sure which ones fit.
If you don't choose a car with the Rsap option (which also doesn't include Wi-Fi), you don't need to install an antenna cable. Do you have the larger MFA display in your car so you can also use the phone interface? The phone interface cannot be used through the RCD310.
http://www.carsystems.pl/volkswagen,c1.html
"There are plenty available there. If you have an MFA+ display, you can get one that doesn't require an MFL and then control it via the MFA display. Alternatively, you can also install an RCD510 and use it to control the FSE."
