Hello.
Does anyone know how the driving mode selection (Normal, Eco, Sport) works, or can provide me with a detailed source of information about it?
I've read that the steering, climate control, and lights can be changed. However, I'm only interested in modifications to the engine electronics.
I tried to create three meaningful full-throttle logs (extended data, torque limits in Nm) with the aforementioned B8 engine producing 110 kW, but I didn't see any significant differences. However, I selected too many data points, which resulted in a low resolution.
The torque limit remains unchanged. I consistently see a maximum of 393 Nm, with 431 Nm under smoke conditions and 410 Nm when pressing the accelerator pedal fully.
Which measurement values should I select to ensure sufficient resolution when logging data?
Should only the accelerator pedal response curve change? Does anyone have any comparative logs of the three modes?
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 14-08-2026, 23:42.
