Advanced Measurement Data Overview
Post18-07-2016, 14:12    Subject: Advanced Measurement Data Overview Quote
Is it possible to print the extended measurement data of a control unit as a list (for overview purposes, without displaying the actual measurement values)?
Thank you.
Translated on 18-09-2026, 5:00.
Post18-07-2016, 18:52    Subject: Advanced Measurement Data Overview Quote
Hello Herbert,
I'm sorry, but I'm not aware of any practical way to do that.
Post18-07-2016, 20:26    Subject: Advanced Measurement Data Overview Quote
You can select all the measurements in the selection window (using Shift+Enter), but copying with Ctrl+C still doesn't work.
It's really annoying that the list could have been used to create a kind of "should/is" comparison with comments.
A suggestion for Ross-Tech?
Translated on 18-09-2026, 5:01.
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 17.8.0: Advanced Measurement Data On-Board Diagnostics (OBD)
No new posts VCDS 805.2: Where is the Extended Measurement Channel Block? On-Board Diagnostics (OBD)
No new posts Important: Extended Measurement Channels for VCDS via UDS Diesel Engine Technology
No new posts Measurements On-Board Diagnostics (OBD)
