TDI Engine Problems: 1.2L 3-Cylinder Runs Rough
onclebenz
Karma: +0 / -2   Thank you, like it!
1987 Mercedes-Benz SL Class
Post20-09-2016, 10:09    Subject: TDI Engine Problems: 1.2L 3-Cylinder Runs Rough Quote
It's about a 1.2 TDI engine in an Audi A2, and it's running very roughly.
I've compared it to the identical 1.2 TDI engine in the Lupo.
It runs much smoother.
The engine is not running smoothly, and the car is vibrating a lot.
Performance is present... where should I start looking?
die anderen Autos stehen in der "Garage"
LUPO 3l 1,2 TDI MKB: ANY Mod.Jahr 2001 220000km
MERCEDES 200D Bauj.1966 KM ??
VW T4 2.5i Multivan Bauj. 1994 240000 KM
Translated on 31-08-2026, 23:59.
Post20-09-2016, 10:52    Subject: TDI Engine Problems: 1.2L 3-Cylinder Runs Rough Quote
First, use VCDS to check the idle speed control in the measurement blocks of the engine control unit. Then, further investigate the cylinder that exhibits the corresponding anomaly. icon_idea.gif
Translated on 01-09-2026, 0:00.
onclebenz
Post30-10-2016, 8:36    Subject: TDI Engine Problems: 1.2L 3-Cylinder Runs Rough Quote
Hello!
It was due to a PD element. I replaced all the PD elements and was able to use used ones.
They might be a bit older and look a little different, but they work perfectly fine.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts 525d runs on 4 cylinders during startup and smokes excess... On-Board Diagnostics (OBD)
No new posts 2.7tdi läuft extrem unruhig im Stand Diesel Engine Technology
No new posts 1.6 TDI CAYC: Running on 3 Cylinders Only Diesel Engine Technology
No new posts A6 AFB Engine: Hard Brake? Troubleshooting. Diesel Engine Technology
