Webasto W-Bus: A6 4F OBD2 Pinout
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Burnsi
Post21-10-2016, 9:18    Subject: Webasto W-Bus: A6 4F OBD2 Pinout Quote
The question is already in the title.
I want to have my Webasto TT auxiliary heater, which was originally installed by Audi, diagnosed.
Translated on 03-10-2026, 17:56.
Karma: +807 / -0   Thank you, like it!
Post21-10-2016, 9:59    Subject: Webasto W-Bus: A6 4F OBD2 Pinout Quote
If your auxiliary heater was installed from the factory, it is already integrated into the vehicle's diagnostic system and can be accessed using appropriate diagnostic software, such as VCDS.
If it's an aftermarket solution, it depends on how it was integrated into the vehicle. If the diagnosis of the auxiliary heater is performed via the K-line, it can be connected to pin 15 of the diagnostic connector (L-line or K2-line).
Depending on the control unit version, the auxiliary heating control unit can be accessed either via the K-Line and VW protocols, or using the Webasto diagnostic software.
See:
Ich kann den Text nicht übersetzen, da ich keinen Zugriff auf den Inhalt der angegebenen URL habe.
Translated on 03-10-2026, 17:57.
No new posts P1000 - OBD2 System Test Incomplete Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI Tuning: Mileage Limit? Diesel Engine Technology
No new posts TDI Turbochargers: Which Charger Fits Your Engine? Diesel Engine Technology
No new posts Immobilizer: Audi 100 2.5 TDI - Starting Year On-Board Diagnostics (OBD)
