Hello Diesel Enthusiasts.
I'm new to this forum
, but I've always read posts here.
It's a really great forum. Keep up the good work.
Now I'm also experiencing a problem with my Skoda, which has a 1.9 TDI PD engine (engine code: BLS) and a 6-speed DSG transmission (LQS).
It occasionally happens that when I'm driving the Skoda, I feel a jerking sensation from the engine
. It's as if the engine is losing power and then accelerating again
. This is also noticeable on the tachometer, which fluctuates up and down, and as I mentioned, you can feel it while driving.
Then, for 2-3 weeks, I don't experience the problem at all, and the engine runs normally.
I've now taken my Skoda to two different authorized service centers.
But unfortunately, the problem was not found
There are no errors stored in the engine control unit.
One garage added an additive to my fuel tank to clean the EGR valve, but that didn't achieve the desired result either.
And the other garage also checked the error memory, but they didn't find any errors in the engine control unit either.
They then suggested that it might also be due to the mechatronics of the DSG transmission.
However, I don't want to replace that mechatronics unit yet
because it's quite expensive.
By the way, the engine has a mileage of 192,000 kilometers.
Now, I hope one of you has another idea or tip about what it could be
, and as mentioned, the problem occurs sporadically.
Thank you for your tips and assistance.
Best regards, Snaker.
