CAN Bus Car Scanner: RKS+CAN Troubleshooting
Koja79
2004 Volkswagen T5
Post20-11-2016, 18:53    Subject: CAN Bus Car Scanner: RKS+CAN Troubleshooting Quote
Hello there...
Today, I wanted to try reading data from two vehicles in our company fleet using the cable mentioned above: a Fiat Ducato from 2012 and a Peugeot Boxer from 2009.
"Neither of them can be read. I then tried it on other vehicles, but unfortunately, without success."
Am I doing something wrong? The software is definitely installed.
VG
Translated on 28-09-2026, 1:19.
Post20-11-2016, 19:01    Subject: CAN Bus Car Scanner: RKS+CAN Troubleshooting Quote
OBD2 via CAN-Bus is mandatory for passenger cars starting in 2008. The vehicles you mentioned are not passenger cars Personal cars and likely still use the K-Line for diagnostics.
Why don't you try it on a car manufactured from 2008 onwards, as stated in the product description for the RKS+CAN.
Translated on 28-09-2026, 1:20.
Benni
Post20-11-2016, 22:43    Subject: CAN Bus Car Scanner: RKS+CAN Troubleshooting Quote
You also need the right expertise to use VCDS. While you can read OBD data (emissions-related errors, things relevant for the inspection) from vehicles made by other manufacturers, you can't access the individual control units. At least, that's been my experience with the cars I've tried it on.
Translated on 28-09-2026, 1:21.
Koja79
2004 Volkswagen T5
Post21-11-2016, 7:20    Subject: CAN Bus Car Scanner: RKS+CAN Troubleshooting Quote
This is not VCDS, which I also own. I also cannot use it to read out the data from the vans, but I am aware of that.
@Rainer,
"Too bad, I assumed that the vans were included. I'll try it out on a 2015 Golf later. You're probably right."
VG Jan.
Translated on 28-09-2026, 1:22.
No new posts VAG Vehicles 2002: Coolant Leak Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD II Interface: PWM, VPW, ISO 9141-2 Support Diesel Engine Technology
No new posts Read Misfire Codes: Diagnose & Troubleshooting On-Board Diagnostics (OBD)
No new posts Can the radio code be read out? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Read Drive Away Assist Control Unit Directly? On-Board Diagnostics (OBD)
