DPF not regenerating (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
dieselschrauber Post26-01-2017, 19:31
The DPF (Diesel Particulate Filter) often cannot be regenerated, and the amount of soot continues to build up until a forced regeneration is necessary. If you wait too long and the soot load is too high, the diesel particulate filter must be replaced because regeneration is no longer possible or makes sense in the vehicle. The corresponding measured values from the engine control unit can be checked using VCDS.
The following conditions must be met for the DPF to be normally regenerated by the engine control unit:
- Coolant temperature is sufficient (thermostat is functioning correctly).
- If installed: Oil level sensor/oil temperature sensor in the oil pan must be functional. Oil temperature and oil level must be sufficient.
- The differential pressure sensor at the DPF is functional and the values are within the normal range (see the collection of values for DPF differential pressures).
- Temperature sensors on the turbocharger and DPF are functioning correctly.
- AGR functional (not always necessary depending on the engine, but it definitely facilitates regeneration as the engine warms up noticeably faster).
Even if the conditions mentioned above are met, the DPF can still become overloaded due to excessive soot or smoke generation from the engine.
- Leak in the intake air system, indicated by noticeably high measured air mass values despite normal or low actual boost pressure.
- Bodged tuning / DIY tuning / Makeshift tuning
- Damage to the turbocharger or engine, oil mist in the exhaust stream.
Since the oxygen sensor is located between the turbocharger and the DPF, this should manifest as lower oxygen sensor readings under load, compared to identical, properly functioning vehicles.
 DPF (Dieselpartikelfilter) und Lambdasonde
 File size:  284.07 KB
 Viewed:  21997 times
Translated on 13-07-2026, 21:32.
Ratings - DPF not regenerating
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Regeneration: Frequent Intervals Explained Diesel Engine Technology
No new posts Seat Alhambra 2.0 TDI constantly regenerating Diesel Engine Technology
No new posts Sharan DPF: Regenerates Every 30km Diesel Engine Technology
No new posts Regenerated Skoda Octavia 2.0 TDI CR - Every 50km Diesel Engine Technology
