Performance fluctuations in PD115
joop
Post28-05-2003, 10:00    Subject: Performance fluctuations in PD115 Quote
Hello!
My friend is having problems with his Golf 4.
During driving, the performance fluctuates... similar to a limp mode.
I suspect the LMM (lambda sensor), but the error codes are...?
The error codes in the memory are:
- ABS control unit error:
Sensor for lateral acceleration G200
- Engine control unit error:
Vehicle speed signal - signal too large
Thank you in advance for your help.
Best regards
DaBibo
Post28-05-2003, 21:31    Subject: Hmm... Quote
Wheel sensors?
Have them checked to see if they all give the same readings on a straight road, without any fogging.
The LMM isn't always to blame *g*
No new posts TDI PD115: Timing Belt Change - What to Replace? Diesel Engine Technology
