Golf V BKC engine shakes/vibrates until approximately 60°C
chli1976
Karma: +185 / -0   Thank you, like it!
Post05-04-2017, 13:31    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
I have a Golf V that vibrates or jerks when accelerating until the coolant temperature reaches approximately 60°C.
The owner personally replaced the dual-mass flywheel and the PD (positive displacement) piping, and measured the compression (30-32 bar on all cylinders).
He mentioned that it doesn't run smoothly even when idling, but I didn't notice anything myself. I'll let it cool down now and try again.
During the test drive, in addition to the jerking, I could also hear a loud, nail-like sound.
I noticed nothing unusual in the MWB 013-018-023 data except that the LL (likely referring to a specific data field) shows a value of 8 twice for cylinder 2, and once during driving at timestamp 240.97, only for cylinder 1, showing a value of 128. Perhaps I was briefly experiencing thrust at that moment.
Of course, the error memory is empty.
Log-WVWZZZ1KZ6W105665-226600km.txt
 File name:  Log-WVWZZZ1KZ6W105665-226600km.txt
 File size:  9.64 KB
 Downloaded:  494 times
LOG-01-013-018-023.CSV
 File name:  LOG-01-013-018-023.CSV
 File size:  83.12 KB
 Downloaded:  542 times
VCDS
Post05-04-2017, 13:54    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
Did you measure the 60°C coolant temperature, and if so, did you see the reading in the instrument cluster's data blocks or in the corresponding data block of the engine control unit?
The temperature sensor is a dual sensor, with one sensor for the combination unit and one for the engine.
If the engine detects a coolant temperature that is too low, this would explain the knocking, as a result of which the fuel injection timing is significantly adjusted towards "early". icon_idea.gif
It's best to replace the temperature sensor; it often malfunctions, is inexpensive, and very quick to replace.
chli1976
Post05-04-2017, 15:00    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
I checked it in the engine control unit.
I thought I saw something on the corresponding material safety data sheet.
The car has been chipped for 5 years.
VCDS
Post05-04-2017, 15:23    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
It would have been useful to log the start of the injection process... or to have a video showing the sound of the engine.
Possibly, the woman/girlfriend added several liters of gasoline. Also, it also works quite well. icon_cool.gif
chli1976
Post05-04-2017, 15:59    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
I will now start logging the injection start time.
The temperature sensor is at least equal to the fuel and intake air temperature when the system is cold.
VCDS
chli1976
Post05-04-2017, 19:06    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
Here are the SB logs, and everything is within the expected range.
LOG-01-004-003-018.CSV
 File name:  LOG-01-004-003-018.CSV
 File size:  8.47 KB
 Downloaded:  364 times
LOG-004-003-018.csv
 File name:  LOG-004-003-018.csv
 File size:  8.47 KB
 Downloaded:  380 times
VCDS
Post05-04-2017, 20:13    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
Made at what coolant temperature? This is crucial, as the start of funding is highly dependent on that. icon_smile.gif
chli1976
Post05-04-2017, 20:44    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
From 20°C to approximately 65°C.
My Hex-Net is acting up a bit with this control unit, as you can see at the end of the first log.
VCDS
chli1976
dieselschrauber likes this.
Post20-04-2017, 16:56    Subject: Golf V BKC engine shakes/vibrates until approximately 60°C Quote
A lifter was broken. Okay, bitte gib mir den deutschen Text, den du in zwei Teilen aufgeteilt hast. Ich werde ihn dann für dich ins Englische übersetzen.
The owner told me that about 30,000 km ago, a few teeth were broken off the timing belt. He replaced the timing belt kit, and the engine ran perfectly again, until now. It probably got damaged there.
VCDS
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 TDI jerks/shudders Diesel Engine Technology
No new posts Help - Golf Plus 105 hp TDI is shaking/jerking Diesel Engine Technology
No new posts Golf Shakes: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Golf 4 1.6 constantly shaking/vibrating On-Board Diagnostics (OBD)
