Herbert Profi-Schrauber
09-06-2017, 8:24 Subject: VAG 1301 Diagnostic Tool |
Does anyone happen to have access to a VAG 1301 diagnostic tool, or a table with its adjustment values and resistance values?
I need a resistor with a resistance value that will allow me to adjust the fuel gauge to a reading of 280.
I have a table from Bentleypublishers, but the specific value I need isn't included, and the interpolation between the existing values is a bit inaccurate.
Translated on 25-10-2026, 18:59.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
09-06-2017, 11:07 Subject: VAG 1301 Diagnostic Tool |
"Could you please provide the existing table or enter the table into Excel? This would allow you to not only draw a straight line through the values, but also to create curves of different degrees. This should help to determine the missing value relatively accurately."
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 25-10-2026, 19:00.
Profile PM Garage |
09-06-2017, 14:37 Subject: VAG 1301 Diagnostic Tool |
Of course, I can perform a linear regression using those values.
The correlation coefficient (KK) reaches 0.9999 with a sufficiently high power, but the straight line (slope of 0.5 Ohms per VAS1301 unit) has an offset of approximately 9 Ohms, and I'm unsure whether this is a systematic measurement error or a characteristic of the VAS 1301.
That's why my question.
Translated on 25-10-2026, 19:01.
