Mileage Meaning for Automatic Transmission - Block 109
alexandererlangen
Post23-02-2018, 10:53    Subject: Mileage Meaning for Automatic Transmission - Block 109 Quote
I constantly have problems with my automatic transmission.
Now I've noticed that when I go to "2-Transmission" and then "08-Meas. Blocks" in VCDS, and then change the setting in Group 109, the following line appears:
140370 km, 84.00%, 13.20%, 3.20%.
Mileage
"The percentages are not labeled."
"It is about:"
VAG Number: 0AM 300 050 P
Component: GSG DSG AG7 403 9030
Labelfile: 0AM-927-769.CLB
My total mileage is significantly lower than 140,370 km.
Therefore, I would like to know what this value means and whether the car has more mileage than indicated.
Schöne Grüße
Alexander
Translated on 25-08-2026, 14:00.
gnasch likes this.
Post23-02-2018, 11:10    Subject: Mileage Meaning for Automatic Transmission - Block 109 Quote
Hello.
My total mileage reading is significantly below 140370 km.
Therefore, I would like to know what this value means and whether the car has more kilometers on it.
Unfortunately, I can't comment on the percentages, as I'm seeing them for the first time. Perhaps certain load conditions are involved, and someone else might know more.
Regarding the mileage, the engine control unit, for example, creates its own "mileage" by integrating the speed information, which should be roughly the same as what is displayed on the speedometer. If I remember correctly, a maximum deviation of 5% is acceptable, but in practice, it is usually less.
Most likely, the transmission control unit performs a similar function, which would be logical.
What is the difference between your displayed mileage and the actual mileage?
PS: That's why I only buy new cars (imported from other countries) or cars from people I know. You wouldn't believe how often I've been asked for information about "mileage tampering" throughout my life, so I've drawn my own conclusions from the extremely high percentage of such inquiries.
Translated on 25-08-2026, 14:03.
No new posts Used Porsche Mileage: What to Look For General Tips
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measurement Block Analysis Help On-Board Diagnostics (OBD)
No new posts Fake Mileage: Ibiza 6L Car Problems On-Board Diagnostics (OBD)
No new posts Wahren Kilometerstand auslesen On-Board Diagnostics (OBD)
No new posts Check Passat 3BG mileage Electrical Systems, Vehicle Electronics, Multimedia
