Debris and fragments in engine oil bind (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » General Tips
Karma: +787 / -0   Thank you, like it!
Post26-08-2017, 14:00    Subject: Debris and fragments in engine oil bind Quote
Older engines had a magnet in the oil drain plug, which removed and held iron-containing wear particles from the engine oil. Unfortunately, this is rare, as in my case, due to motor defect, steel particles can appear in the engine. However, a magnet of this type would be helpful in preventing the particles from circulating within the engine.
The oil pump, although, Rule one: Replace the oil filter, and the oil filter will filter out further particles from the oil. If small steel particles are still filtered out before the oil pump, this cannot be harmful.
You can either purchase a drain screw with a magnet as an accessory or attach a strong magnet to the existing steel drain cover, for example, with super glue.
The benefit of a magnetic oil drain plug is usually quite small, more of a "peace of mind" feature: You rarely have larger metal shavings floating around in the engine, but in case of damage, a magnet in the engine oil is very useful. Due to the extremely low cost of a magnetic oil drain plug, I consider it a worthwhile accessory.
Best regards, Rainer
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Ratings - Debris and fragments in engine oil bind
No new posts Wood chips in diesel filter - TPI? Diesel Engine Technology
No new posts Nockenwelle eingelaufen oder nur Hydrostößel?Späne im ... Diesel Engine Technology
No new posts Motor oil for PD with WIV? Diesel Engine Technology
No new posts Motoröl für 2.0 PD TDI (BMN) Diesel Engine Technology
