alexandererlangen
24-06-2017, 15:21 Subject: Ross Tech V2 NET: Won't Stay in Slot? |
I've only recently started using the VCDS device. However, it doesn't seem to fit very securely in the vehicle and appears to be slipping out over time.
I've now noticed that in the 2-pin configuration, one pin has two middle pins that are significantly longer than the rest.
Is it the same for you? Schöne Grüße
Alexander
Translated on 25-09-2026, 2:12.
chli1976 Profi-Schrauber
24-06-2017, 20:25 Subject: Ross Tech V2 NET: Won't Stay in Slot? |
Yes, that's normal. VCDS
Translated on 25-09-2026, 2:13.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
25-06-2017, 16:54 Subject: Ross Tech V2 NET: Won't Stay in Slot? |
The two middle, longer pins are for vehicle ground and signal ground. It is intentional that these two pins connect to the vehicle first when plugged in.
Profile PM WWW Garage |
