Question regarding valve operation and valve stem sealing.
haehnlein
Post21-05-2003, 19:23    Subject: Question regarding valve operation and valve stem sealing. Quote
Hi, Schraubers,
I am currently in the process of removing the valve guides on our Audi TDI 1Z with 270,000 km (engine head is removed). In the process, one of the valve guides has been damaged (it is uneven due to the clamp pressure) icon_evil.gif. However, the valve fits perfectly. Is it bad if the valve guide is slightly uneven in the upper area?? Shouldn't that have little influence on the valve movement or icon_question.gif icon_confused.gif Furthermore, the crankshaft seal is located above it.
Unfortunately, I don't have a specific "patent" method for removing these annoying shaft seals on the TDI. How do you manage to get them out? Do you use a specialized tool like a "Hazetzange" or a "Matrawerkzeug"? With the good old TD, at least you could remove the seal along with the valve spring retainer and then knock it out from the outside icon_rolleyes.gif
Maybe it's time to put a new head on the LL? Well, never change... Furthermore, we all want to know how long something like this lasts icon_razz.gif
____________
Kein Auto mehr!
haehnlein
Post27-05-2003, 21:33    Subject: Question regarding valve operation and valve stem sealing. Translating...
[Translating...]
also der Motor läuft wie eine Eins->scheint kein Problem zu sein icon_cool.gif
Für den Ausbau der Ventilschaftabdichtungen kann ich die Hazetzange 791-8 empfehlen icon_exclaim.gif icon_exclaim.gif Ging superleicht damit icon_wink.gif
____________
Kein Auto mehr!
Varianti
Post28-05-2003, 19:36    Subject: Question regarding valve operation and valve stem sealing. Translating...
[Translating...]Also ich glaube nicht, dass du mit einer Zange die Ventilführung quetschen kannst. Falls du es doch geschafft haben solltest, sollte das Ventil dann auf keinen Fall mehr passen, da dies eine schöne Passbohrung ist.
Ich nehme immer eine Facom Zange (Ist zwar auch nicht billig gewesen, funktioniert aber recht gut). Die unterstützt einen aber nur beim zupacken. Ziehen muss man dann schon selber.
Wichtiger ist aber, dass du den richtigen Klöppel bzw. das richtige Gefühl zum einschlagen hast. Beschädigst du da die Dichtlippe oder die Ringfeder(und das sieht man nicht auf den ersten Blick) war die ganze Aktion umsonst.
haehnlein
Post28-05-2003, 20:43    Subject: Question regarding valve operation and valve stem sealing. Translating...
[Translating...]
Hi Varianti,
ich habe es erst mit einer normalen Zange versucht und durch zu hohen Druck die Ventilführung etwas beschädigt. Das Ventil ging aber ohne Probleme rein->dürfte also kein Problem sein icon_confused.gif
zum Schutz der Dichtlippe gibt es die Schutzhülse, die auf das Ventil gesteckt wird. Zum Aufschieben der Dichtung nehme ich den Aufdrücker von Matra (8mm Ventilschaft). Die Dichtung muss aber nicht reingeklopft werden icon_exclaim.gif Etwas Druck genügt und man merkt, wie die Dichtung im unteren Bereich sich festsetzt icon_wink.gif
____________
Kein Auto mehr!
No new posts Valve Stem Seal: Questions & Answers Diesel Engine Technology
No new posts Valve Guide Problems: How to Diagnose Diesel Engine Technology
No new posts AHU Damper Actuator Unavailable? Diesel Engine Technology
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
