P0046 - Turbocharger Boost Control Circuit Malfunction, Magnetic Valve Area (Solution)
Karma: +806 / -0   Thank you, like it!
Post03-08-2017, 14:31    Subject: P0046 - Turbocharger Boost Control Circuit Malfunction, Magnetic Valve Area Quote
Error code P0046 - Turbocharger Overboost Control Circuit Malfunction indicates a problem with the boost control solenoid valve.
Either the solenoid valve/actuator is electrically or mechanically faulty, or there is a defect in the electrical wiring or connectors.
Caution: The turbocharger pressure may become too high (risk of damage to the turbocharger or engine) or too low, as proper regulation is not guaranteed.
The following error codes are related: P0045, P0047, P0048, and P004A.
Ratings - P0046 - Turbocharger Boost Control Circuit Malfunction, Magnetic Valve Area
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts Throttle Body Motor: Circuit Fault (P2100) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost control solenoid valve. Power loss (A3 TDI) Diesel Engine Technology
No new posts Lambda sensor control (electrical) (Fault in the electric... On-Board Diagnostics (OBD)
No new posts PD Unit Power Issues: Troubleshooting Stuttering On-Board Diagnostics (OBD)
No new posts Glow Plug Circuit Fault: P0672 & P0673 Codes Diesel Engine Technology
