Undergrkg87
24-09-2017, 17:37 Subject: VCDS V2: Customization Options & Settings |
Hello community,
Does anyone know how to access the correct adaptation window in the central electronics module for Steuergeräte  ?
When I go to the customization settings, this window appears for me.
| Description: |
| File size: |
135.06 KB |
| Viewed: |
2413 times |
| Description: |
 Download |
| File name: |
Scan-WAUZZZ8V0F1023411-20170923-1317-41897km.txt |
| File size: |
20.54 KB |
| Downloaded: |
527 times |
Translated on 14-10-2026, 2:40.
24-09-2017, 17:48 Subject: VCDS V2: Customization Options & Settings |
You've taken such a nice, large, white Screenshot. Just read what's written there. Expand the drop-down menu, see what options are available, and select one.
| Description: |
| File size: |
2.59 KB |
| Viewed: |
408 times |
Translated on 14-10-2026, 2:41.
Profile PM WWW Garage |
Undergrkg87
25-09-2017, 11:55 Subject: VCDS V2: Customization Options & Settings |
Hi there,
You're really searching through that dropdown menu, aren't you?
I actually expected this window in the adaptation.
| Description: |
| File size: |
723.77 KB |
| Viewed: |
530 times |
25-09-2017, 12:07 Subject: VCDS V2: Customization Options & Settings |
What you're expecting is how it used to work with cars, which are now almost considered classic cars. Now, instead, a dropdown list appears.
Translated on 14-10-2026, 2:42.
Undergrkg87
25-09-2017, 12:16 Subject: VCDS V2: Customization Options & Settings |
Okay, I guess I'll just have to accept it.
How can I search for channels using the search function? I want to be able to enter a channel number directly, but entering "36" doesn't work.
Sorry, but maybe I'm just not understanding something right now  .
25-09-2017, 12:22 Subject: VCDS V2: Customization Options & Settings |
Undergrkg87 wrote: | Okay, then I guess I'll just have to accept it.
Sorry, but maybe I'm just not understanding something right at the moment  | .
Since the "channel number" is no longer fixed, searching for it is rarely useful. However, while it might be the same for the same control unit, it can be completely different for a different model.
IMHO, there's no way around skimming the texts.
Translated on 14-10-2026, 2:43.
Undergrkg87
25-09-2017, 13:01 Subject: VCDS V2: Customization Options & Settings |
Okay, I'll take a look.
Thank you for the good and quick response, Rainer.
Best regards, Mario.
Translated on 14-10-2026, 2:44.
