Two things again, please:
I've read a lot here already, and I'm completely overwhelmed now.
There's supposed to be some kind of part that I need to connect to something.
make sure to control it, otherwise the ESP will fail.
full throttle.
What exactly is it, and how is it done?
Where and through which opening/screw?
Do I need to add diesel fuel so that the pump works?
starting up for the first time / won't start / engine won't turn over.
Does it run dry? / Is it running dry?
