DPF Regeneration: Display & Troubleshooting
sewi176
Post13-07-2022, 19:38    Subject: DPF Regeneration: Display & Troubleshooting Quote
Hello everyone,
I was wondering if there's a way to display on the instrument cluster when the DPF is actively regenerating. Sometimes you find yourself in a situation where a regeneration has started, and you might only need to drive another 5km to complete it. However, as a driver, you generally don't realize this is happening. Therefore, it would be beneficial if I could somehow detect when a DPF regeneration is in progress.
Can this be adjusted or programmed using VCDS?
Hi sewi... I'm curious to see if there's a solution for this.
Superb 2.0 TDi, 260tkm MKB: CBBB
Translated on 27-07-2026, 1:16.
Karma: +1354 / -0   Thank you, like it!
dieselschrauber likes this.
Post13-07-2022, 21:16    Subject: DPF Regeneration: Display & Troubleshooting Quote
Hi there,
I would also like to know the solution. Unfortunately, with my vehicles (an A4 with engine code CJCD and a Golf 7 with engine code DDYA), I can only determine it by ear and by observing the idle speed.
Translated on 27-07-2026, 1:17.
Karma: +647 / -0   Thank you, like it!
Post14-07-2022, 5:02    Subject: DPF Regeneration: Display & Troubleshooting Quote
Hi there.
I know that some postal service/DHL vehicles, like the Caddy SDI, were equipped with a specific type of lamp. There was also a special warning sticker inside the vehicle indicating that the engine should not be turned off if the lamp was illuminated.
https://www.motor-talk.de/bilder/dpf-leuchte-auf-kurierfahzeug-codieren-g68195615/filter2-i207725796.html
Translated on 27-07-2026, 1:18.
sewi176
Post14-07-2022, 14:34    Subject: DPF Regeneration: Display & Troubleshooting Quote
Rüdi wrote:
Hello.
I know that some postal service/DHL vehicles, like the Caddy SDI, were equipped with a specific type of lamp. There was also a special warning sticker inside the vehicle indicating that the engine should not be turned off if the lamp is illuminated.
Sure, here's the translation:
"Hello there."
Thank you for the link; I read the post, and it seems like no one has a solution either. But we shouldn't give up hope too quickly.
Best regards, sewi.
Translated on 27-07-2026, 1:19.
chli1976
Post14-07-2022, 19:52    Subject: DPF Regeneration: Display & Troubleshooting Quote
There was once an update for the engine control unit from the postal service; you could compare the old and new software versions to potentially find it.
VCDS
Translated on 27-07-2026, 1:20.
No new posts Lupo Door Problems: 6X1 MJ 2002 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Display operating hours with VAG-COM? On-Board Diagnostics (OBD)
No new posts FIN: Show in Message Summary again On-Board Diagnostics (OBD)
No new posts VAG-COM: Start Catalytic Converter Regeneration On-Board Diagnostics (OBD)
No new posts Regeneration: Questions & Status Update Diesel Engine Technology
