CAN Bus Passat 3C: Brief Interruption
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
JMS
Post19-01-2018, 19:14    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Hello Diesel Mechanic Community,
I'm new here and I hope someone can help me. My name is Jörg, I'm just over 50 years old, and about 25 years ago I worked for a few years in an independent workshop (mostly bodywork). I trained as a toolmaker. Until now, I've always been able to get my cars repaired without outside help. However, I'm now facing a problem that I can't solve myself, and I'm hoping you can help me:
On December 25th, 2017, the alarm system (DWA) of my Passat 3C (2006) went off in the afternoon. I unlocked and locked the doors once, and then it stopped. On December 27th, the battery was so drained that even the central locking system didn't work. Since then, the battery has always been completely discharged by the next morning (after a 40-minute drive in the morning and evening). After the weekend, the battery is so low again that the car barely starts, or only with jump starting. I measured the quiescent current using a clamp meter. The current drops to about 300mA, then rises again to approximately 1.2 / 1.4 A. This repeats roughly every 10 seconds.
"I can also see this using VCDS. If I don't lock the doors, the control modules remain inactive. In the error memory, both door control units show the "thermal protection active" error. I can clear the error, but it reappears immediately after the next "ignition on." The window lifters were definitely not activated. When I check the control unit using the measurement block 001, it shows "thermal protection inactive." The second error message that I can't explain is in module 69 (trailer). It indicates an implausible signal at terminal 15. Measurement block 001 says "status of terminal 15: off," while measurement block 006 says "status: on."
I'm also hearing a clicking sound from the comfort control unit. After each click, the bus state changes.
"I'm sorry for the long text..."
My question is now: Who is responsible for activating the control units? Are both door control units defective, or are the door locks the problem? Is the trailer control unit malfunctioning and causing this disturbance?
I am hoping for help or assistance.
Jörg.
Log-WVWZZZ3CZ7E069041-315720km.txt
 File name:  Log-WVWZZZ3CZ7E069041-315720km.txt
 File size:  11.68 KB
 Downloaded:  426 times
Translated on 15-08-2026, 20:01.
Post19-01-2018, 20:13    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I would, as it is the simplest and simultaneously produces a conspicuous error message, temporarily remove the trailer control unit for testing purposes and observe the situation. icon_idea.gif
Translated on 15-08-2026, 20:04.
JMS
Post19-01-2018, 20:36    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Hello dieselmechanic. Thank you for the quick response. What do you mean by "removing" it? Do you mean disconnecting the power supply to the control unit (STG), pulling a fuse, or removing it from the parts list using VCDS?
Jörg.
Translated on 15-08-2026, 20:05.
Post19-01-2018, 21:09    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Disconnect the plug and remove it from the parts list.
Translated on 15-08-2026, 20:06.
JMS
Post19-01-2018, 21:15    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Thank you very much. I will test it tomorrow.
Jörg.
dieselschrauber likes this.
Post19-01-2018, 21:53    Subject: CAN Bus Passat 3C: Brief Interruption Quote
In the "09" section of the extended measurement data, the last 4 alarms should also be included, along with their triggering reasons icon_idea.gif.
JMS
Post20-01-2018, 13:56    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I have now disconnected the control unit for trailer operation and removed it from the parts list. The current state is that the bus system goes into a quiet mode, which lasts until the quiescent current drops to approximately 35mA (sometimes several minutes). Then, there's a click in the central locking system (ZKS), and the quiescent current increases to approximately 800mA. After about 5 seconds, there's another click, and the quiescent current decreases again. The only change now is that the quiet state lasts longer. Could it be the door control units? I'm starting to despair. I've been working on this problem for about 3 weeks (measuring, removing fuses, measuring, etc.). The only advantage of all this is that I now have VCDS. Previously, I used CarPort to solve my problems. My wife got tired of my complaining and surprised me with a Hex-V2 icon_smile_thumb_up.gif. (Unfortunately, not from you). Nevertheless, I hope for further help in the forum.
Jörg
Translated on 15-08-2026, 20:08.
JMS
Post20-01-2018, 14:00    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Hello Roger,
I checked the logs from 2009. I don't find any errors in the extended measurement blocks. Did you mean the error paths (I can't recall the exact name)? There are many entries there that all start with "DTC" (?).
Jörg.
Translated on 15-08-2026, 20:09.
Post20-01-2018, 15:09    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Do not look for errors, but rather for the source of the alarm, the trigger cause, or similar.
Translated on 15-08-2026, 20:10.
JMS
Post20-01-2018, 19:11    Subject: CAN Bus Passat 3C: Brief Interruption Quote
Okay, I'll search the manual and the internet to find some information about how to proceed. Thanks for the tip.
Jörg.
Post20-01-2018, 19:14    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I just saw that he also has a separate size 46. I'll take a look at that too.
Translated on 15-08-2026, 20:11.
JMS
Post20-01-2018, 20:23    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I will do it. Thank you icon_smile_thumb_up.gif.
JMS
Post21-01-2018, 18:21    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I've looked at the alarm sources and trigger conditions. The trigger conditions are understandable because they are described in plain text. However, the alarm sources don't make sense to me. For number 19, I might guess it refers to the control system (STG), but what about number 14? Can you help me understand this?
Thank you and best regards.
Jörg.
Address 46: Comfort System (3C0 959 433 M)
17:29:53
1. Alarm trigger, alarm horn.
2. Alarm trigger, alarm horn.
3. Alarm trigger, alarm horn.
4. Alarm trigger, alarm horn.
1. Alarm source 14.
2. Alarm source: 0.
3. Alarm source 19.
4. Alarm source: 0.
Translated on 15-08-2026, 20:12.
Post21-01-2018, 20:16    Subject: CAN Bus Passat 3C: Brief Interruption Quote
It looks like the backup horn is defective. This has happened in similar cases before. For example, it has its own battery inside.
The numbers mean nothing to me.
Translated on 15-08-2026, 20:14.
JMS
Post21-01-2018, 20:42    Subject: CAN Bus Passat 3C: Brief Interruption Quote
I'm assuming that the backup horn is the alarm horn, right? It's been broken for years. So I don't need to look any further in that area. Or am I mistaken about something?
Jörg.
Translated on 15-08-2026, 20:15.
Post22-01-2018, 9:01    Subject: CAN Bus Passat 3C: Brief Interruption Quote
According to Speicher, the horn is definitely the trigger. This is monitored for manipulation. Eventually, the defective battery will run out and cause the circuit board with the control logic to corrode. From that point on, it malfunctions and can naturally also wake up everything else on the bus.
However, that doesn't explain why the central ventilation system ended up being used for thermal insulation...
Translated on 15-08-2026, 20:16.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Cooling water leak: Why it stops and starts? Diesel Engine Technology
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
