VW Passat 3BG: Bad Starting Issues?
tonimemo
Post03-02-2018, 2:06    Subject: VW Passat 3BG: Bad Starting Issues? Quote
Hello everyone,
The topic has definitely been discussed many times before.
I need your help. I've tried using information from other posts as much as possible, but unfortunately without success so far.
I have a Volkswagen Passat 3BG Variant 1.9 TDI PD AVB, manufactured in 2002.
My problem with the engine is that it doesn't start well, whether it's hot or cold.
When it's cold, it starts a little better. However, once it's running and still slightly warm, it starts almost instantly after being turned off. But if it reaches operating temperature after a longer ride, it becomes almost impossible to restart.
The following items have already been exchanged:
Reciprocating pump.
In-tank fuel pump.
Diesel filters.
Knuckle sensor.
Crankshaft sensor.
Mass airflow sensor.
Vacuum hoses.
Coolant temperature sensor.
Fuel temperature sensor.
AGR has been completely removed and deactivated.
The fuel tank was completely cleaned during the replacement of the in-tank pump.
I'm starting to get desperate. I've already swapped all the relays, which is fortunate because we have two identical vehicles in the family.
The error memory is also completely 'CLEAN'.
I also checked the timing: it's currently at -1.2 degrees.
All the PD elements are within tolerance.
I don't have any diesel in the oil.
When it's on, it runs smoothly and there are no fluctuations in speed.
I've attached a video in the attachment that I recorded after a longer drive.
VW Passat 3BG: Bad Starting Issues? - B2222F48-806D-4E07-BEEA-9E2F2AB49DD8.MOV
 File size:  6.48 MB
 Viewed:  1285 times
Translated on 04-08-2026, 5:04.
Post03-02-2018, 13:17    Subject: VW Passat 3BG: Bad Starting Issues? Quote
I think you won't get very far without a diagnostic tool, which brings us to...
We cordially invite you to participate. The requirement for posting in diagnosis-related topics (everything that requires a vehicle diagnostic system) is...
a diagnostic tool from a diesel mechanic's shop, or...
our software, including KDataScope and KPower, or the Diesel Mechanic license.
a vehicle diagnostics support key.
landing. We can proceed when... see the quote below.
Translated on 04-08-2026, 5:08.
No new posts Doku Passat 3B, Seatbelt front does not retract properly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Very poor starting behavior for gasoline engines! On-Board Diagnostics (OBD)
No new posts Renault 1.9 DTI has (very) poor starting performance... Diesel Engine Technology
No new posts springt kalt sehr schlecht an Diesel Engine Technology
No new posts Golf 3 TDI springt sehr schlecht an LOG MWB 5 Upload
