"I've been having a problem with my Ford Galaxy WGR, manufactured in 1995, with a 1Z engine for the past 3 days. I've been checking and measuring various things for the past 2 days, and I've searched online, but so far without success."
Problem:
Day 1: The engine won't start, and if it does start, there's no response from the accelerator pedal.
Error MSG.
65535 - Device defective 00 - 00 - -
17978. Master switch locked. P1570 - 35-00 - -
Neither of the errors can be deleted.
Error: WFS Storage.
01177 - Mstg 65-10: Not authorized - intermittent.
can be cleared for engine start.
Day 2: Engine won't start.
Then we warmed up the ESP a bit (using a hairdryer).
Engine starts, immediately revs up, no problem.
Gas pedal response.
"Then the engine starts and runs at 840 RPM, but there's no [something missing - e.g., spark, fuel, etc.]."
Response to the accelerator pedal is almost instantaneous when you shift gears.
The consumer (high beam) dies; restart.
840 RPM for a few minutes, then it starts.
to rev up all by myself.
Error MSG.
Error: WFS Storage.
Day 3: Many connectors, relays, and fuses.
checked; verified; approved.
Throttle pedal sensor, 0-100%, measured with VCDS and multimeter.
also also idle switches.
Brake light switch, OK.
Clutch switch iO
WFS stage open, PCB visually OK.
ESP measured.
Temperature sensor, resistive.
Spool 1: 5.4 Ohms.
Spool 2, 10.2 Ohms.
Needle probe with a resistance of approximately 100 kOhms.
Actuator diagnostics: all actuators are functioning, except for one.
high and low heating settings.
Engine starts despite active WFS (reading coil disconnected).
Ignition switch removed, signal too weak) and turns.
"It's extremely high right away, and then it reaches 3000."
parked
Error MSG.
Error: WFS Storage.
I'm currently stuck and don't know where to start.
Is the Mstg really defective?
Is the ESP adjustment mechanism secure?
"Mstg" is a 028 906 021 P. Can I connect one with a different letter suffix to it, or only one with a "P" suffix?
I would greatly appreciate any support you can offer.
Greetings.
Manfred.
Translated on 26-10-2026, 1:57.
