| Boost behavior of VAG TDI engines, engine code AHF | ||||||||||||
| dieselschrauber |
Here are some screenshots showing the turbocharger pressure behavior on the VAG 1.9l TDI engine AHF.
However, the engine was not original, but... It was upgraded to 101 kW (137 hp) using an auxiliary control unit. Otherwise, only minor flow optimizations were made to the connections between the turbocharger and the intercooler. The charging curve looks similar, but at approximately 2000 minutes-1, the pressure is only about 0.85 bar. At approximately 3200 minutes-1, the pressure is approximately 0.9 bar, which gradually decreases to 0.7 bar starting at approximately 4100 minutes-1. Looking back, it can be said that the values may be considered too low, as the regulated boost pressure... It should be at approximately 0.95 bar. If someone measures their car and doesn't achieve the values shown in the diagrams, that's not necessarily a problem. The important thing is that the actual boost pressure roughly follows the target value. If the actual boost pressure is more than 15% (~a limit determined by experience) below or above the specified target value, even after several seconds of full load, a defect should be suspected. In the meantime, ADAC Fürth has performed another power measurement. However, the results are only comparable to a limited extent because the first measurement was performed on a different test bench. The measured value is now 103 kW (140 hp). This is an increase, but only within the range of measurement accuracy. However, it must be said that during the first measurement, a fan was blowing directly onto the intercooler, while in the new measurement, the fan was positioned relatively far in front of the car and was blowing very weakly; it was not producing more wind than a speed of 40 km/h. Well... To explain the operation of the boost pressure control system Maximum boost pressure is approximately 2000min{-1} ![]() The color of the measured values corresponds to the color of the curves, the purple line.
Slow decrease at 2700min-1 Further decrease at 3800min-1 From 3800min-1 it remains constant until 4116min-1, further measurements were not taken.
How the turbocharger pressure regulation works.
. This description was provided by the forum participant.
- the turbocharger is driven by the exhaust gas flow. - the powered loader increases the fresh air or Blend promotion. into the combustion chambers. - More mixture in the combustion chambers results in larger... Exhaust gas volumes. - Larger volumes of exhaust gas drive the turbocharger more forcefully. Sure, here is the translation of the text from German to English: "an . . ." - . . . which further increases the fuel-air mixture in the combustion chambers. etc. Since the exhaust flow is, in a way, the product of the air-fuel mixture and the engine speed,
Rest position where the gas turbine is not supplied with air. is being. As the vacuum pressure increases, the guide vanes direct an increasing amount of exhaust gases. onto the gas turbine, and the boost pressure increases with sufficient exhaust gas flow. Such a fluctuating boost pressure would result in a rocking Make acceleration noticeable. To rule out such phenomena, the boost pressure control function was... The engine control unit was designed with a relatively slow response time through software. This leads to... with rapidly increasing boost pressure, leading to a brief exceeding of the... Set point values, until the control system has adjusted the pressure regulating valve to the point where... The boost pressure drops back to the target value. Near the target value, the regulation is also more careful. as in cases of significant deviations. This is how it works when all components are functioning normally. Even with abrupt accelerator pedal movements, the turbocharger pressure regulation can oscillate. certainly avoidable. In the same maneuver, starting from approximately 1,500 min-1, the peak value reaches only about 1.2 bar; at higher... Gears have even fewer (measured due to the slower increase in rotational speed. on a 1997 AFN engine). Excessive pressure spikes can, in some cases, lead to charger damage (over-speeding). can lead to hose connections slipping in the intake passages, the intercooler bursting, or other damage. If the boost pressure, for example, cannot be reduced to the target value due to a blocked VTG mechanism or an excessively shortened VTG linkage, the engine control unit reduces the fuel injection quantity in order to lower the boost pressure in this way. At the same time, the engine power is significantly reduced.
Dipl.-Ing. (FH) Rainer Kaufmann - Original VCDS mit KPower, KDataScope und Dieselschrauber Support Translated on 04-07-2026, 12:49. |
| Ratings - Boost behavior of VAG TDI engines, engine code AHF | |
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 4 - View ratings |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop für Kfz-Diagnosegeräte. Parse time: 0.256s
