Mariotto01
13-03-2018, 10:59 Subject: AZV motor pump nozzle sealing |
Hello everyone.
My problem concerns a Volkswagen Touran.
Motor AZV
Unfortunately, I couldn't find anything using the search function.
The engine starts very poorly when it's warm, it misfires significantly, but it always eventually starts.
I wanted to replace the seals on the injector pumps.
The nozzles have two clearly visible O-rings of the same size.
There's still a small O-ring included in the set.
Where is he going?
Does the nozzle need to be unscrewed for that?
The nozzle does not have a seal at the bottom because it is conical.
I would appreciate it if someone could help me here.
Best regards, Mario.
Autoservice Profi-Schrauber
14-03-2018, 0:00 Subject: AZV motor pump nozzle sealing |
It goes in the upper part of the PD (presumably a piece of equipment), it's the O-ring of the piston pin, which you can see above the spring.
