AZV motor pump nozzle sealing
Mariotto01
Post13-03-2018, 11:59    Subject: AZV motor pump nozzle sealing Quote
Hello everyone.
My problem concerns a Volkswagen Touran.
Motor AZV
Unfortunately, I couldn't find anything using the search function.
The engine starts very poorly when it's warm, it misfires significantly, but it always eventually starts.
I wanted to replace the seals on the injector pumps.
The nozzles have two clearly visible O-rings of the same size.
There's still a small O-ring included in the set.
Where is he going?
Does the nozzle need to be unscrewed for that?
The nozzle does not have a seal at the bottom because it is conical.
I would appreciate it if someone could help me here.
Best regards, Mario.
Post14-03-2018, 1:00    Subject: AZV motor pump nozzle sealing Quote
It goes in the upper part of the PD (presumably a piece of equipment), it's the O-ring of the piston pin, which you can see above the spring.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Injector Lifespan: VW TDI 115PS Engine Durability Diesel Engine Technology
No new posts GRA für Pumpe Düse (AJM) Diesel Engine Technology
No new posts Pump-nozzle Diesel Engine Technology
No new posts Problem Pumpe-Düse AXR Diesel Engine Technology
