MAP sensor for 1.9 TDI engine with code AHU
DavidGolf3Syncro
Post15-03-2018, 14:41    Subject: MAP sensor for 1.9 TDI engine with code AHU Quote
https://shop.dieselschrauber.org/en/ladedrucksensor-250kpa-intern--p-291.php
Can I easily install this sensor in my Golf 3 TDI Syncro with a 90 hp engine (engine code AHU), or what should I be aware of?
David
Translated on 17-07-2026, 13:02.
Post15-03-2018, 15:35    Subject: MAP sensor for 1.9 TDI engine with code AHU Quote
Yes, just be sure to note the different pin assignments; the description is included.
Best regards, Rainer Kaufmann.
Translated on 17-07-2026, 13:03.
No new posts Coolant Temp Sensor vs. Diesel Temp Sensor for AJM PD Diesel Engine Technology
This topic is locked, you cannot edit or reply. VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G2... Diesel Engine Technology
