Question: Info on CAN-Bus Interface RKS+CAN variants
paschgu
Post26-04-2018, 21:30    Subject: Question: Info on CAN-Bus Interface RKS+CAN variants Quote
Good evening.
I am interested in these two products, but I was unable to reach anyone in Switzerland by phone or through any contact form. Unfortunately, no one has responded.
I am interested in this product: CAN-Bus Interface RKS+CAN.
What is the difference between the two versions?
- CAN-USB Interface Kit
- OBD2 Diagnostic Kit
I only need to read and clear error codes, and if possible, reset the service indicator.
Furthermore, this product includes:
- VCDS diagnostic system HEX-V2 / unlimited license => I have various vehicles that I read data from, reset service intervals, and potentially perform other tasks. Service that requires coding.
Thank you for your feedback and your assistance.
After that, I can safely place my order.
You're welcome.
Pascal.
Karma: +808 / -0   Thank you, like it!
Post26-04-2018, 21:49    Subject: Question: Info on CAN-Bus Interface RKS+CAN variants Quote
Hello Pascal,
Unfortunately, you only spoke to the automated phone system when I was sick. The callback regarding the recovered voice was unfortunately forgotten, but you posted here. icon_cool.gif
I would be interested in this product: CAN-Bus Interface RKS+CAN.
The CAN-USB Interface Kit includes licenses for all programs from the RKS+CAN installation package, which are:
- KCANMonitor (CAN bus sniffer/monitor)
- KOBD2Check (OBD2 diagnostic software)
- KDataScope (Log Analyzer)
- KPower (power measurement)
The OBD2 diagnostic kit is missing the license for KCANMonitor.
It mainly involves reading and clearing error codes, and possibly... If it is possible, please postpone the service.
Using OBD2, it is possible to read error codes from the engine control unit, but resetting the service interval is not supported by the OBD2 protocol. It works with Audi, Seat, Skoda, and VW vehicles using VCDS and...
VCDS diagnostic system HEX-V2 / unlimited => because I have several vehicles that I read data from / reset service intervals and, if necessary, Service that requires coding.
VCDS also has an OBD2 mode.
paschgu
Post26-04-2018, 23:13    Subject: Question: Info on CAN-Bus Interface RKS+CAN variants Quote
Hello Rainer,
Thank you for your feedback.
That means I only need the VCDS diagnostic system, specifically the HEX-V2. Can I also use this to read and clear error codes for other brands?
Best regards, Pascal.
Post27-04-2018, 7:57    Subject: Question: Info on CAN-Bus Interface RKS+CAN variants Quote
As far as the engine control unit (ECU) is concerned, and if it is accessible via K-Line or CAN, then yes.
paschgu
Post15-05-2018, 17:31    Subject: Software Quote
Hello Rainer,
I now have VCDS at home. How do I access the KOBD2Check software so that I can read and clear error codes for other brands as well? Can I use the same software as for the VCDS diagnostic system with the HEX-V2?
Thank you.
Post15-05-2018, 18:28    Subject: Question: Info on CAN-Bus Interface RKS+CAN variants Quote
Hi Pascal,
RKS+CAN is a proprietary interface and has nothing to do with VCDS. Available like the rest in the automotive diagnostics shop.
If you're only interested in OBD2 functionality for non-VAG vehicles, you can also use the OBD-2 button within VCDS. However, the RKS+CAN offers additional features such as extended readiness PIDs, very fast data logging, and a software/CVN check for many VAG engine control units.
In addition, KDataScope automatically unlocks its full functionality (dongle function).
Overall, the primary purpose of the RKS+CAN device is to sniff and log data on the CAN bus using KCANMonitor.
No new posts Question about diagnostic interface On-Board Diagnostics (OBD)
No new posts What are some low-cost options for reading OBD data? On-Board Diagnostics (OBD)
No new posts Turbo Boost Increase for AKN Engine: Info Diesel Engine Technology
No new posts Pop-off Valve: Usefulness and Purpose Diesel Engine Technology
