Audi A3 8L engine misfire - MKB AVU
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
vag-driver
Post30-05-2018, 14:16    Subject: Audi A3 8L engine misfire - MKB AVU Quote
The car jerks during acceleration and runs below the idle speed when idling. When the mass airflow sensor is disconnected, the jerking is almost gone. The fuel filter was recently replaced. The error related to the fuel tank ventilation valve (N80), which was caused by a leak, has now been resolved.
What continues to worry me is the obvious overpressure in the cylinder head. When the engine is running, the oil filler cap does not get sucked in, but rather hovers almost above the opening.
The fuel metering system error for bank 1 persists. What else could it be besides the mass airflow sensor?
Tuesday, May 29, 2018, 21:11:29:19385
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: RKS 18.2.1.0
Data as of: 20180313 DS287.1
Vehicle Identification Number: WAUZZZ8LZ1A062470 License Plate:
Mileage: 205779. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 8L (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: DRV\06A-906-033-AVU.lbl
Part number: 06A 906 033 J.
Part: SIMOS33 1.6L 2V 00HS3488
Encoding: 00211
Operating number: WSC 06435
VCID: 2645C09DC2ACB4747B-5178
WAUZZZ8LZ1A062470 AUZ5Z0YD270014
2 error codes found:
16555 - Fuel quantity measurement system (Bank 1)
P0171 - 35-10 - System too lean - Intermittent.
17834 - Tank ventilation valve (N80)
P1426 - 35-10 - Interruption - Sporadic.
Readiness: 0000 0000
Address 03: Brake Electronics Label file: DRV\1C0-907-37x-ESP-F.lbl
Part number: 1C0 907 379 E.
Part: ESP FRONT MK60 0104
Encoding: 0011266
Operating number: WSC 06435 000 00000
VCID: 2C5132B58C408E24AD-5178
"1 error found:"
01314 - Engine Control Unit.
013 - Please read the error memory - Intermittent.
Address 08: Climate Control/Heating Module. Label file: DRV\8L0-820-043-1D.lbl
Part number: 8L0 820 043 H
Component: A3 CLIMATE CONTROL UNIT 0101
Encoding: 01040
VCID: 2D573FB1E75A872CBA-259E
No error codes found.
Address 15: Airbag
Label file: DRV\8L0-959-655-AI8.lbl
Part number: 8L0 959 655 J.
Part: Front and Side Airbag 4008.
Encoding: 00104
VCID: 458767115FEA5F6C52-5178
Address 17: Control panel module
Label file: DRV\8L0-920-xxx-17.lbl
Part number: 8L0 920 900 F
Component: COMBINATION INSTRUMENT + TRIP COMPUTER. M73 D52
Encoding: 08042
Operating Number: WSC 00000
VCID: 2E5538BDEA5CFC3483-4B18
or error codes are not supported by the control unit.
or communication errors occurred.
Address 35: Central Locking
Label file: DRV\8D0-862-257.lbl
Part number: 8D0 862 257 B
Component: Central locking pump, radio. D16.
Encoding: 14913
VCID: 2C5132B5DC408E24AD-4F3A
Ende----------------------------(Duration: 04:2http://shop.dieselschrauber.org/en-----------------------------
Andreas
Post30-05-2018, 20:01    Subject: Audi A3 8L engine misfire - MKB AVU Quote
Injector not clogged and fuel pressure okay?
Karma: +1333 / -0   Thank you, like it!
Post30-05-2018, 22:25    Subject: Audi A3 8L engine misfire - MKB AVU Quote
That's normal. The cooling system ventilation is connected to the central ventilation system. Where should the vacuum come from?
vag-driver
dieselschrauber likes this.
Post13-06-2018, 8:08    Subject: Audi A3 8L engine misfire - MKB AVU Quote
Since neither I nor my neighbor had time to further investigate the problem, it was taken to the Audi service center.
After replacing the ignition coil and spark plug wires, the cause of the problem is obviously resolved.
Andreas
Post13-06-2018, 8:39    Subject: Audi A3 8L engine misfire - MKB AVU Quote
Thank you for your feedback! I wouldn't have expected that... but okay. icon_eek.gif
vag-driver
Post13-06-2018, 10:34    Subject: Audi A3 8L engine misfire - MKB AVU Quote
It's surprising too. Let's see if it stays that way. I will report back on this matter if, hopefully, it occurs.
Andreas
Post13-06-2018, 11:04    Subject: Audi A3 8L engine misfire - MKB AVU Quote
Perhaps, for example, a new fuel filter as a replacement for the clogged one would have been too cheap. icon_cool.gif
I don't understand why a misfire on one cylinder would cause the engine to run lean.
Karma: +643 / -0   Thank you, like it!
Post13-06-2018, 13:19    Subject: Audi A3 8L engine misfire - MKB AVU Quote
If the problem was with the ignition system, the engine would have had to run unevenly, or the corresponding cylinder would have been noticeably misfiring, as I recently experienced with a Lupo with an AUC engine. In addition, the throttle body was clogged with carbon deposits.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New Audi 80 1Z 1.9 TDI smokes heavily and misfires Diesel Engine Technology
No new posts Audi CAGA: Engine Failure & Complete Breakdown Diesel Engine Technology
No new posts BMP is twitching Diesel Engine Technology
No new posts SQ5 is shaking Diesel Engine Technology
