Reconfigure Engine Control Unit Connectors
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post07-08-2018, 14:03    Subject: Reconfigure Engine Control Unit Connectors Quote
Hi there,
If you want to completely reconfigure the connectors for the engine control unit, where can you get suitable tools and parts?
I would take the fully wired connector from a scrapped vehicle.
To rework it, you would first need a good tool for removing the pins.
Then you'll definitely need new crimp connectors and a suitable crimping tool.
I would also take the appropriate cables from an old wiring harness; there should be plenty available there.
Where can I find wire stripping tools, connectors, and a crimping tool?
The MSG would be an EDC 15.
VW 074 906 018 AJ or Bosch 0281010461.
Translated on 29-07-2026, 8:08.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Doku, n.lÜschb. Fehler im Motorsteuergerät 2.5l V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts T5 Motorsteuergerät On-Board Diagnostics (OBD)
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
No new posts Connect the Thermo Top to the engine control unit On-Board Diagnostics (OBD)
