Uwe46
10-02-2020, 8:31 Subject: High Idle, No Gas, Glow Plug On? |
my car:
Skoda Octavia 1U5.
Year of construction: 2000.
350,000 km
1.9 TDI
Engine AHF.
Perhaps you can help me with an initial assessment, something just happened:
My Octavia starts, but immediately runs with an elevated idle speed of just under 1100 RPM.
He had never done that before; it always maintained a constant, quiet, and normal idle speed.
"Also, it's not taking any gas at all. Absolutely none, no matter how much I press the pedal."
And after a few seconds, the indicator light started to glow.
Otherwise, there were no warning lights that came on.
What could that possibly be now?
Thank you in advance for your help!
Translated on 01-10-2026, 3:43.
djteam
Joined: 10/03/2005 Posts: 15 Karma: +1 / -1 Location: ÖsiLand 1995 Volkswagen Golf Premium Support
10-02-2020, 12:31 Subject: High Idle, No Gas, Glow Plug On? |
Typically, the error occurs in the accelerator pedal (plausibility check) -> Automatically enters emergency mode with increased idle speed.
Often, there is moisture present, which could be due to the connectors on the control unit or inside the connector box in the water tank.
best regards
christian.
P.S.: Reading the error codes will give you certainty.
Audi A4 1,9TDI quattro AFN
Jetta 2 PL 16V 129PS
Translated on 01-10-2026, 3:45.
Profile PM Garage |
Uwe46
10-02-2020, 16:52 Subject: High Idle, No Gas, Glow Plug On? |
Okay, thank you in advance.
The control unit is also located in the water tank, as is the connector box.
The question is whether simply standing there with a hairdryer will be enough.
Or whether there might be other areas that could be affected.
Unfortunately, it's not easy to get to the workshop to have the diagnostic tool connected now, especially since the car isn't even drivable.
Translated on 01-10-2026, 3:46.
Bertil Profi-Schrauber
dieselschrauber likes this. |
10-02-2020, 19:36 Subject: High Idle, No Gas, Glow Plug On? |
Something like that?
Translated on 01-10-2026, 3:47.
Herbert Profi-Schrauber
10-02-2020, 20:08 Subject: High Idle, No Gas, Glow Plug On? |
Here's one way to troubleshoot without guessing:
https://shop.dieselschrauber.org/en/
Uwe46
10-02-2020, 22:13 Subject: High Idle, No Gas, Glow Plug On? |
Hi, I managed to find another friend with a diagnostic tool, and the old Octavia is throwing the following error codes:
00668 - Voltage at terminal 30.
27-00 - implausible signal.
18047 - Throttle position sensor (G79) + (G185).
P1639 - 35-10 - Implausible signal - Intermittent.
What does "getting a new accelerator pedal" mean? Or could it be something else entirely?
Translated on 01-10-2026, 3:48.
Uwe46
11-02-2020, 15:33 Subject: High Idle, No Gas, Glow Plug On? |
Perhaps the easiest thing to do is to order a used accelerator pedal, connect it, and see if it works again.
Translated on 01-10-2026, 3:49.
matthiasTDI96 Profi-Schrauber
dieselschrauber, djteam and tobias_ likes this. |
11-02-2020, 17:13 Subject: High Idle, No Gas, Glow Plug On? |
Perhaps the easiest approach is to follow the steps outlined here. Check if any connectors are damp or even waterlogged, and inspect the wiring harness. There are guides available online that explain how you can use measurement techniques to troubleshoot the potentiometer yourself.
In the worst-case scenario, you can obtain a replacement part.
Uwe46
12-02-2020, 9:29 Subject: High Idle, No Gas, Glow Plug On? |
"I'll take a closer look at everything this weekend. Thanks for your help!"
Translated on 01-10-2026, 3:50.
Uwe46
17-02-2020, 17:45 Subject: High Idle, No Gas, Glow Plug On? |
Hi, quick update:
I got a new accelerator pedal for 15€ from a junkyard, installed it in a few minutes, and the car was running again  .
Thank you for your help!
I'm still glad that I didn't have to organize a massive troubleshooting effort or disable any control units, but that the problem was so easy to fix.
