Opel Astra 2008: Specs, Review & Price
Dragec
Post06-11-2018, 21:56    Subject: Opel Astra 2008: Specs, Review & Price Quote
Why can't I see any error codes for my Opel Astra, 2008? I'm using an RKS+CAN interface.
Regards, Drago.
Translated on 02-10-2026, 14:37.
Post06-11-2018, 23:12    Subject: Opel Astra 2008: Specs, Review & Price Quote
Hello Drago,
Is the engine control unit (ECU) responsive, i.e., does it display any diagnostic information?
What kind of errors do you expect in which control unit?
Translated on 02-10-2026, 14:38.
Dragec
Post07-11-2018, 21:21    Subject: Opel Astra 2008: Specs, Review & Price Quote
Hello! The engine control unit is accessible, but...
I can also read some values while the engine is running, but I can't read the error code. The display in the car shows an error somewhere, with a symbol that looks like a key.
If I then turn off the engine and restart it, the symbol usually disappears from the display.
Greetings, Drago.
Post07-11-2018, 23:15    Subject: Opel Astra 2008: Specs, Review & Price Quote
Okay, the error is probably not related to exhaust emissions... Could you please copy the scan and post it here?
A picture of the error message/symbol on the dashboard would also be helpful.
Translated on 02-10-2026, 14:39.
Karma: +1098 / -0   Thank you, like it!
dieselschrauber likes this.
Post08-11-2018, 15:34    Subject: Opel Astra 2008: Specs, Review & Price Quote
It is the service indicator that is grinning at you there.
Get the maintenance done.
2. Turn off the ignition, remove the key.
3. Reinsert the ignition key, but the ignition remains off.
Press and hold the button for the daily mileage counter for 3 seconds.
5. Service indicator appears: InSP...
Press and hold the button for the daily mileage counter.
7. Depress the brake pedal and hold it down.
8. Turn on the ignition, but do not start the engine.
Press and hold the button for the daily mileage counter and the brake pedal.
10. The service indicator light is blinking and turns off after approximately 10 seconds.
11. The display shows the mileage until the next service.
Depending on the vehicle's coding, a timer (12 or 24 months) also starts, even if the mileage until the next service has not yet been reached. For diesel vehicles, it is 50,000 km, and for gasoline vehicles, it is 35,000 km (Eco Service Flex) or a flat rate of 30,000 km (Eco Service normal).
It happened to me repeatedly that when resetting the service indicator, the values for the trip odometer were unintentionally also lost. One too many presses, and it happened.
Here's the translation:
"Important caveat: The aging of the engine oil is assessed in some way, and this depends on the specific model and engine. This could mean that the service indicator will reappear relatively quickly. To my knowledge, it can be reset via the diagnostic system. I'm not sure if it's possible to completely disable the oil monitoring system."
Translated on 02-10-2026, 14:41.
Dragec
Post11-11-2018, 20:33    Subject: Images: High-Quality Photos & Stock Images Quote
Hi, I'm sending the pictures. Best regards, Drago.
 File size:  175.42 KB
 Viewed:  228 times
 File size:  11.13 MB
 Viewed:  176 times
 File size:  10.74 MB
 Viewed:  171 times
Translated on 02-10-2026, 14:44.
Post12-11-2018, 18:32    Subject: Opel Astra 2008: Specs, Review & Price Quote
Thank you, it looks good!
Have you checked Hutfahrer's suggestion yet?
Dragec
Post12-11-2018, 21:11    Subject: Opel Astra 2008: Specs, Review & Price Quote
No, I will try. Best regards, Drago.
Translated on 02-10-2026, 14:45.
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Upgrade of MMI Basic Sound System Audi A6 4F up to KW35/2008 Troubleshooting & Guides
No new posts Opel Astra 1,7tds Dieselpumpe Bj 96 Diesel Engine Technology
No new posts Rail pump, Opel Astra, likely faulty Diesel Engine Technology
This topic is locked, you cannot edit or reply. (gelöst) Opel Astra G springt nicht an!!! Diesel Engine Technology
No new posts Fehlende Leistung bei meinem Opel Astra G On-Board Diagnostics (OBD)
