Throttle Pedal Issue Audi A3 1.6 TDI (2010)
ch914er
Karma: +5 / -2   Thank you, like it!
2005 Audi A4
Post19-12-2018, 0:50    Subject: Throttle Pedal Issue Audi A3 1.6 TDI (2010) Quote
Hello.
While reading out various measurement values, I accidentally bumped into the accelerator pedal.
According to VCDS, the maximum power output is only 80%.
Is that correct?
The vehicle is an Audi A3 1.6 TDI, manufactured in 2010.
Chris.
Translated on 17-09-2026, 13:59.
Post19-12-2018, 14:11    Subject: Throttle Pedal Issue Audi A3 1.6 TDI (2010) Quote
Is this a 1.6 TDI engine with the problematic engine control unit related to the AGR valve? What are you trying to tell us?
Translated on 17-09-2026, 14:00.
ch914er
2005 Audi A4
Post19-12-2018, 16:40    Subject: Throttle Pedal Issue Audi A3 1.6 TDI (2010) Quote
It was just a question of whether this is normal.
However, it seems that in the Audi Cabrio, the value is displayed as 77.7%.
I'll be checking out my A4 Avant this weekend.
Okay, you can close this topic and give me the third negative karma.
VG Chris.
Translated on 17-09-2026, 14:01.
Post19-12-2018, 21:14    Subject: Throttle Pedal Issue Audi A3 1.6 TDI (2010) Quote
Everything is fine, you can close the topic and give me the third karma minus.
Not necessary.
But perhaps you could describe your vehicle and any changes that have been made in the area where you're experiencing problems (e.g., the engine), along with the basic data (OBD scan, error codes).
You should naturally expect us to be critical when third parties make changes, and in such cases, we may refrain from implementing those changes by carefully analyzing and understanding the logic behind them. Everyone is responsible for their own success.
Translated on 17-09-2026, 14:02.
Post19-12-2018, 21:33    Subject: Throttle Pedal Issue Audi A3 1.6 TDI (2010) Quote
No, we're only critical when we're asked, and it's frustrating when changes are released all night after we've already provided x answers.
This is actually quite simple... you can have it reprogrammed, which is always a good solution... icon_rolleyes.gif
Translated on 17-09-2026, 14:03.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS error message on a Seat Ibiza 1.6 TDI CR, year 2010 Upload
No new posts VCDS: Missing ROD File - Seat Ibiza 1.6 TDI CR 2010 On-Board Diagnostics (OBD)
No new posts Log File: 2010-07-11, 3C BMR Data Upload
No new posts Logfile: Marcas Data from April 28, 2010 Upload
