brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
dieselschrauber likes this. |
17-05-2019, 19:13 Subject: Mercedes V6 OM642: Misfire Troubleshooting |
Hello everyone,
I have a question about an OM642 engine in a friend's Viano.
The engine starts, after a somewhat longer idle time, and potentially more noticeably in combination with colder temperatures, but not on all cylinders.
With a little bit of encouragement, the rest will quickly join in.
Ansonsten völlig unauffälliger Motorlauf. Lperformance is available.
Attached is an LL (Low-Level) idle speed regulation assessment from StarDiagnose. In my opinion, it also looks completely fine, doesn't it?
What would you check next?
Mileage: 200,000 km.
Error memory is empty.
Excellent maintenance condition.
Thank you!
| Description: |
| File size: |
379.3 KB |
| Viewed: |
1536 times |
Translated on 05-09-2026, 5:21.
Herbert Profi-Schrauber
18-05-2019, 6:35 Subject: Mercedes V6 OM642: Misfire Troubleshooting |
How about the spark plugs?
During the test (is the engine warm?), at least five cylinders are performing well, while one seems to be slightly weaker.
Translated on 05-09-2026, 5:23.
18-05-2019, 7:32 Subject: Mercedes V6 OM642: Misfire Troubleshooting |
Hello!
The glow plugs have not been checked yet. Do you think a faulty glow plug could cause such effects at temperatures above 0 degrees Celsius?
During the test, the coolant temperature was 59 degrees Celsius, according to the log.
Maximum deviations can be up to ±5mg per dose, which is different from Volkswagen's standards, but that seemed acceptable to me.
Translated on 05-09-2026, 5:24.
18-05-2019, 11:47 Subject: Mercedes V6 OM642: Misfire Troubleshooting |
Perhaps he uses the glow plugs to start the engine and also lets them run for a short time afterwards.
You should observe the idle speed immediately after starting the engine. In the test you performed, the engine was already warmed up.
Translated on 05-09-2026, 5:25.
dleds
04-06-2019, 10:52 Subject: Mercedes V6 OM642: Misfire Troubleshooting |
brezelmann01 wrote: | Hello!
During the test, the coolant temperature, according to the protocol, was 59 degrees.
Maximum deviations can be +-5mg per injection, which is different from VW, but that also looked quite good to me. |
Well, just because Mercedes-Benz states something doesn't mean it's necessarily true. Volkswagen also says that 1 liter of oil consumption per 1000 km is still within the acceptable range.
"Percentage-wise, relative to the target amount, approximately +/- 60% of the energy used is recovered at the crankshaft. If this were acceptable, I wonder why the injectors need to be programmed into the engine control unit."
In this case, the difference between the worst and the best result is only 15%, so I would first check the spark plugs. Especially in Sprinter and Vito vans, they are often left in for too long... it's not always easy to access them.
Translated on 05-09-2026, 5:26.
