Phonebook to RNS-E/BT module for voice control.
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
AA-K4
Post24-03-2019, 12:36    Subject: Phonebook to RNS-E/BT module for voice control. Quote
Can someone help me?
How do you copy the phone's storage to the RNS-E or the Bluetooth control unit so that it works with voice control?
The phone is an iPhone SE!
RNS-E is a size 192!
GOLF4 V6 4MOTION HGP BI-TURBO
A4 8H 2,5 TDI
Translated on 07-08-2026, 17:33.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post24-03-2019, 14:07    Subject: Phonebook to RNS-E/BT module for voice control. Quote
There's no copying involved. It's essentially a separate phonebook that you have to manually fill in verbally. Also, the number of storage slots is very limited. You can find out the commands by asking the voice control for help while on the phone.
I THINK that was something like "save names" or similar.
Unfortunately, it's a bit complicated with the RNS-e system, but that's just because it's an older system.
Translated on 07-08-2026, 17:34.
AA-K4
Post24-03-2019, 14:20    Subject: Phonebook to RNS-E/BT module for voice control. Quote
Okay!
"Thank you!"
A4 8H 2,5 TDI
Translated on 07-08-2026, 17:35.
brezelmann01
dieselschrauber likes this.
Post25-03-2019, 8:57    Subject: Phonebook to RNS-E/BT module for voice control. Quote
Hi!
I just tried it out. You need to go to the address book (using the "Name" button) on the 192 device and create a new entry. Then, use the voice command "save name" and speak the name you want to save.
Pretzelmann01
Translated on 07-08-2026, 17:36.
AA-K4
Post25-03-2019, 11:30    Subject: Phonebook to RNS-E/BT module for voice control. Quote
A4 8H 2,5 TDI
AA-K4
dieselschrauber and brezelmann01 likes this.
Post26-03-2019, 10:12    Subject: Phonebook to RNS-E/BT module for voice control. Quote
Sure, no problem! Here's the translation:
"Thank you very much!"
A4 8H 2,5 TDI
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts @ Tim 27 regarding pump tuning Diesel Engine Technology
No new posts @Thomas regarding Lupo Diesel Engine Technology
No new posts Kulanz Costs: What You Need to Know Diesel Engine Technology
No new posts An OBD Profis wegen Tacho On-Board Diagnostics (OBD)
