KPower Power Measurement - Time intervals between readings
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
tdi_fan
Post19-05-2020, 11:53    Subject: KPower Power Measurement - Time intervals between readings Quote
Hi everyone,
I've been experimenting with KPower a lot lately and have recorded some performance graphs.
I was surprised to see that some measurements looked reasonable, while others had a lot of jagged spikes in the chart, as you can see in the extreme example in "Hinweg_3Gang.PNG".
I took a closer look at the log file recorded with VCDS and saw that there are only a few milliseconds between the measurements, which is because I only recorded the two necessary data points (speed and RPM). I thought that more measurements would normally lead to a more accurate result.
Then, after the import, I deleted some of the acceleration measurements so that there was approximately a 0.5-second interval between the remaining data points. And behold, you obtain a beautiful curve plot named "Hinweg_3Gang_bereinigt.PNG".
I had assumed that KPower automatically performs smoothing, but that doesn't seem to be the case.
Have you had similar experiences?
There might even be a setting in VCDS that allows you to specify the time interval between measurements, which I need to check later. If that's the case, it would solve the problem. You just have to know icon_smile.gif.
 File size:  16.31 KB
 Viewed:  432 times
 File size:  25.61 KB
 Viewed:  363 times
tdi_fan likes this.
Post19-05-2020, 12:20    Subject: KPower Power Measurement - Time intervals between readings Quote
fast. icon_smile.gif It is being smoothed. However, the smoothing algorithm is not designed for such high sampling rates as are now possible.
You can reduce the sampling rate by logging only the values you need.
For reliable measurements, it is desirable to have at least 3 data triplets (time, speed, velocity) per second.
No new posts KPower Leistungsmessung - Datenexport möglich? On-Board Diagnostics (OBD)
No new posts Important: KPower Vehicle Power Measurement, Power Chart Creation On-Board Diagnostics (OBD)
No new posts Passat Variant AKN: Specs, Max Speed & Measurements On-Board Diagnostics (OBD)
No new posts Difference between the Steuergerät for AAT and AEL? Diesel Engine Technology
