Tax Deadlines: Important Dates & Info
thmtomi
Post19-03-2021, 11:10    Subject: Tax Deadlines: Important Dates & Info Quote
Hello.
I have a question for the experts.
Right here in this forum.
I have a 2.0 TDI Audi A5.
replaced the timing belt.
Now I have the error that the...
The glow plug lamp is on, and...
Start-stop system is not functioning.
Could it be that this error, ...
This is because the valve timing...
Does it no longer apply?
Although all markings are related to OT...
fit.
Previously, the error was definitely...
no.
I would appreciate your opinions and responses.
Best regards, Thomas.
Translated on 22-09-2026, 4:23.
Karma: +807 / -0   Thank you, like it!
Post19-03-2021, 11:40    Subject: Tax Deadlines: Important Dates & Info Quote
Hello Thomas,
Theoretically, it's possible, but that would require the timing to be significantly misaligned. It's possible that a cable or connector was damaged during the work, or that it already had a loose connection that is now causing problems. Alternatively, something else could be broken that has nothing to do with the timing belt replacement.
When the indicator light illuminates, it means that the vehicle has at least one error code stored in the engine control unit, and something is not functioning as it should.
Guessing games about which error is present are pointless; use a tool like VCDS to read the error codes, and then you'll know.
In addition, it can also be used to check the accuracy of the timing belt setting (offset between camshaft and crankshaft). icon_wink.gif
Translated on 22-09-2026, 4:25.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in gen... Diesel Engine Technology
No new posts AKN Timing: Schedules & Information Diesel Engine Technology
No new posts TDI V6 Timing: AKN Engine Specs & Guide Diesel Engine Technology
This topic is locked, you cannot edit or reply. Adjusting valve timing 1.9 TDI PD AXR Diesel Engine Technology
