Can a 1.9 TDI BLS engine be rebuilt without an EGR valve?
Audi-20VT
Post02-04-2021, 15:06    Subject: Can a 1.9 TDI BLS engine be rebuilt without an EGR valve? Quote
Hi there,
Currently, I'm experiencing a problem with my A3 8P 1.9 TDI 105 PS BLS where it makes an unpleasant whistling noise from the EGR cooler. However, given that the car has now reached 420,000 km, it's probably not worth investing in expensive repairs. I was therefore considering temporarily blocking the EGR supply line to the cooler as a test.
My question is whether the DPF can still regenerate without the EGR system functioning, or if I risk damaging the DPF, even if it's only for a short test period.
Thank you and best regards,
Sebo.
Translated on 22-07-2026, 7:56.
chli1976
dieselschrauber and Audi-20VT likes this.
Post02-04-2021, 18:40    Subject: Can a 1.9 TDI BLS engine be rebuilt without an EGR valve? Quote
Yes, it's regenerated, but if you don't disable it in the software, an error occurs, and of course, it's not allowed.
VCDS
Translated on 22-07-2026, 7:57.
Wibbing
dieselschrauber likes this.
Post09-05-2021, 11:12    Subject: Flames from the leaking radiator Quote
On the other hand, a leaking radiator can even be dangerous.
Some manufacturers have "updated" the software, sometimes in a preemptive manner, such that the EGR valve does not always close reliably when the filter burns out. I can observe this with the Transit Euro5. This then leads to the EGR cooler burning through, flames erupting, and igniting the plastic parts in the engine compartment: resulting in total damage.
A leaky radiator can cause that to happen as well.
Best regards.
Grandpa Lothar.
Macan, 964-4, Alhambra, Duster
Diesel:Transit 2012 2,2l 140PS
Früher u.A. auch:
Lloyd Alexander TTS,
VW Käfer,1500,T2,Passat,Gölfe,
Audi 72 ,75 ,200Q, S4, Ro80,
Ford 12M, 15M, Glas 1700,
BMW V8,2000, Mini,
Opel Rekord,Kadet,Kapitän,
Benz 180,190,219,220s,
Isabella TS, Kombi, Coupe,
Fiat 850,125,128 C, Ducato244,
Lancia Delta C, Simca Ariane,
Ente, R4, R5, Dacia MCV,
Translated on 22-07-2026, 7:58.
Audi-20VT
Post10-05-2021, 13:41    Subject: Can a 1.9 TDI BLS engine be rebuilt without an EGR valve? Quote
Here's an update: While the EGR cooler was leaking, the exhaust manifold was also leaking, which was causing the noise that needed to be addressed. So, the EGR blocking plates were removed again, and the 1.9 TDI is now running in its standard configuration.
Translated on 22-07-2026, 7:59.
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L, year 1999, ALH engine, with and without automatic ... Upload
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
No new posts EPC without error entry On-Board Diagnostics (OBD)
No new posts 2x2 diagnostic adapter without +12V On-Board Diagnostics (OBD)
