Heibo
29-08-2021, 14:31 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Good morning to you.
I have a question about the "OM 602 DE 29 LA" engine. I have a W461 gdt 290 with the OM 602 DE 29 LA engine, production code: 602.983.
I want to continue driving the car for a long time and would like to buy an engine control unit as a spare, in case it breaks down. The same engine was used in the W210 E290 Turbo as in the G-Class, with the type number: 602.982.
Now, to the question: Can you simply install a control unit from an E-Class into a G-Class? Do they fit directly, or are there any issues involved?
Best regards, Tom.
Translated on 16-07-2026, 20:03.
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
29-08-2021, 14:53 Subject: Subject: Engine Control Unit (ECU) from W210 E290 TD, compatible with W461 GDT 290? |
Heibo wrote: | Good morning to you.
I want to continue driving the car for a long time and I'm going to buy an engine control unit as a spare, in case it breaks down. The W210 E290 Turbo used the same engine as the G-Class, with the type code: 602.982.
Now, to the question: Can you simply install a control unit from an E-Class into a G-Class? Do they fit directly, or are there any problems involved?
Greetings Tom | .
Hello Tom,
You should direct your question to a chip tuner who is familiar with tuning and understanding the specific engine you mentioned, rather than just a reseller.
Generally speaking, it is possible to clone engine control units (ECUs) that have the same electrical specifications but initially different software. It is also important to consider the immobilizer system.
Translated on 16-07-2026, 20:06.
Profile PM WWW Garage |
Heibo
29-08-2021, 14:57 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Okay, I understand. The question is whether all the control units are identical, especially in terms of their connectors. Can I use a unit from an E-Class and adapt it for my G-Class?
Translated on 16-07-2026, 20:08.
29-08-2021, 15:24 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Quote: | | You should ask that question to a chip tuner. |
Generally speaking, however, a generation of control units with a specific type of control unit has the same connector configuration.
For example, a Bosch EDC 17C46 control unit in vehicle A might have the same pin configuration as an EDC 17C46 in vehicle B, even though simply swapping the control units from A to B would not make vehicle B function correctly (due to the immobilizer and different engine control software).
Heibo
29-08-2021, 15:35 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Do you know a reliable chip tuner?
Okay, I'll post my question there then. But based on my gut feeling, I think it will work if the program is adjusted.
I think my car only has a steering wheel lock and no other immobilizer system. But I'm not sure.
Translated on 16-07-2026, 20:10.
29-08-2021, 16:35 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Okay, I don't currently have any statistical data on how reliable Mercedes vehicles are based on people's experiences.
Habe einfach gefragt wer Interesse hätte und würde Dich an ihn weiterleiten.
Posting a picture of the control unit here, where all the important labels can be seen, would still be very helpful.
Heibo
dieselschrauber likes this. |
29-08-2021, 16:43 Subject: Can I install a motor control unit from a W210 E290 TD into a W461 GDT 290? |
Attached is a picture with the identification number.
Thank you.
| Description: |
| Bosch MSA 25.2, Mercedes Benz A 026 545 15 32, Bosch 0 281 001 953 |
| File size: |
217.41 KB |
| Viewed: |
282 times |
Translated on 16-07-2026, 20:11.
