Injection Nozzles for ALH Engines
tdifuzzi
Post26-05-2003, 20:23    Subject: Injection Nozzles for ALH Engines Quote
Hello everyone,
'Can anyone tell me which injectors I need for my ALH engine to achieve more power? I mean, from which engine type, possibly with a part number? And does anyone know the prices for those? Is it enough to just replace the injector nozzles, or do I need to replace the complete injectors?'
Stefan.
Translated on 03-10-2026, 6:42.
tdifuzzi
Post26-05-2003, 20:28    Subject: Injection Nozzles for ALH Engines Quote
Oh yeah, I have a manual transmission!
Translated on 03-10-2026, 6:43.
Post26-05-2003, 21:33    Subject: Fuel Injectors for ALH Engine: Which are Best? Quote
tdifuzzi wrote:
Hello everyone,
Can anyone tell me which injectors I need for my ALH to achieve more power? I mean, from which engine type, possibly with a part number?
Hi Stefan,
I would probably start by trying nozzles from ASV.
Bosch part numbers and prices should be available through the online catalog.
For a set of nozzle (holder) combinations without the possibility of returns, you should be prepared to spend approximately 1000 euros icon_sad.gif.
tdifuzzi
Post26-05-2003, 22:07    Subject: Injection Nozzles for ALH Engines Quote
Oops, 1000 Euro? Da kann ich ja die Düseneinsätze von kw-systems nehmen, die kosten nur 499 Euro und sind speziell für den ALH-Motor entwickelt!!! OdWhat do you mean?
Stefan
Translated on 03-10-2026, 6:44.
Post27-05-2003, 16:17    Subject: Injection Nozzles for ALH Engines Quote
tdifuzzi wrote:
Oops, 1000 euros? Well, I could get the injector nozzles from kw-systems, they only cost 499 euros and are specifically designed for the ALH engine!!! Or what do you think?
Hi Stefan,
AFAIK, the KW nozzles are universal parts for all 66 kW TDI engines.
At least the ASV nozzles fit "perfectly" with the ALH pump, because they are the same.
Translated on 03-10-2026, 6:45.
ole
Post12-06-2003, 14:55    Subject: Injection Nozzles for ALH Engines Quote
I'm completely new here and don't know anything about this chat feature. I hope I don't mess anything up. It would be a shame, because the discussions here are on a really high level.
Regarding which injectors to use for the ALH engine:
'I've been using injectors from the ASV engine in my ALH for 2 years/60,000 km. They are a better option than injectors from the AFN/AHF engines because they are optimized for EU3 emissions standards. Additionally, I have adjusted the EGR system via channel 3.'
My experience: generally, lower fuel consumption with comparable performance, problem-free driving behavior, and a noticeable increase in power.
Furthermore, this measure is validated through test bench experiments (peak pressure, smoke number, etc.), so there is no need to worry about its lifespan.
Ole.
Translated on 03-10-2026, 6:46.
Post12-06-2003, 19:55    Subject: Injection Nozzles for ALH Engines Quote
ole wrote:
I have been using injectors from the ASV in my ALH engine for 2 years/60,000 km. . . . My experience: generally, lower fuel consumption with comparable performance, problem-free driving, and a noticeable increase in power.
Hi.
How about the power consumption display?
Due to the now inappropriate pump characteristic curve, you should actually be seeing a fuel consumption reading that is too low (compared to the refueling amount) icon_rolleyes.gif icon_question.gif.
Translated on 03-10-2026, 6:48.
ole
Post13-06-2003, 8:01    Subject: Injection Nozzles for ALH Engines Quote
Hi Ulf,
I adjusted the fuel consumption display to the maximum possible 15%. This isn't quite enough to compensate for the increased fuel injection volume. There's still a discrepancy of 0.2 to 0.3 liters per 100 km, which is the difference between the displayed consumption and the actual consumption. You can adjust this by reducing the amount through channel 1, or you can simply live with it.
Ole.
Translated on 03-10-2026, 6:49.
Post13-06-2003, 14:27    Subject: Injection Nozzles for ALH Engines Quote
ole wrote:
I adjusted the consumption display to the maximum possible 15%. This is not quite enough to compensate for the increased injection volume...
Hi Ole,
Yes, I thought so too.
Thank you for your confirmation. I have updated the nozzle replacement article accordingly.
Translated on 03-10-2026, 6:50.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Which AHF fuel injectors? Diesel Engine Technology
No new posts TDI Injectors: Which Models Use the Same? Diesel Engine Technology
No new posts Fuel Injection Pump: Which One? Diesel Engine Technology
No new posts Gear Oil Drain Plug: Location & How-To Diesel Engine Technology
