Decode/remove Pace Car flashing on Golf VII
Florian320
2004 Audi Cabriolet
Post16-03-2022, 13:53    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Hi!
I received a request to remove the flashing light feature from a Volkswagen Golf VII because the technical inspection (TÜV) doesn't approve of it.
I am aware that for lamps 16 and 17, I need to select the "Blinking L/R Bright Phase" option for light function A.
I'm not familiar with the other settings or their original values, and I don't know where to find them.
Does anyone know of a resource that explains how different settings should be configured (e.g., light function B, dimming value AB/CD, light control HD AB, light functions C and D, dimming direction CD)?
Florian.
Translated on 12-07-2026, 17:16.
Ich_Can_nix
Karma: +248 / -0   Thank you, like it!
dieselschrauber likes this.
Post16-03-2022, 15:33    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Hello Florian,
If it truly involves decoding, you can compare these values.
Then it will be alright again.
IDE08788-ENG122204-Dynamic blink modes-Door lock blinking: on, active, 4 -> Not active.
IDE08788-ENG122203-Dynamic blink modes-Door lock blinking_to active, 4 -> Not active.
ENG116952-ENG116183-Light16BLK SLB35BLK SL KC9-Light Function C 16, Active blinking function has an associated bit set to 1 in pa_dynamic_blinking, 16 -> Not active.
ENG116952-ENG116185-Light16BLK SLB35BLK SL KC9-Dimming value CD 16.100, 16 -> 0
ENG116952-ENG116187-Light16BLK SLB35BLK SL KC9-Light function E 16, Right turn signal, Bright phase, 16 -> Not active.
IDE05145-ENG116189-Light Configuration-Dimming Value: EF 16.0, 560
IDE05145-ENG116190-Lighting Configuration - Dimming Direction: EF 16, minimize, 560 -> Maximize.
ENG116953-ENG116202-Light17TFL R BLK SRB3TFL R BLK SR KC3-Light function C 17, The active flashing function has an associated bit set to 1 in pa_dynamisch_blinken, 16 -> Not active.
ENG116953-ENG116204-Light17TFL R BLK SRB3TFL R BLK SR KC3-Dimming value CD 17.100, 16 -> 0
ENG116953-ENG116206-Light17 TFL R BLK SRB3TFL R BLK SR KC3-Light Function E 17, Left Turn Signal, Bright Phase, 16 -> Not Active.
ENG116953-ENG116208-Light17TFL R BLK SRB3TFL R BLK SR KC3-Dimming value EF 17.0, 16.0
IDE05145-ENG116209-Lighting Configuration-Dimming Direction EF 17, minimize, 560 -> Maximize.
Michael.
Translated on 12-07-2026, 17:20.
Karma: +1333 / -0   Thank you, like it!
Post16-03-2022, 15:38    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Hi there,
"That's just a gimmick that people buy to fancy up their car. Maybe the customer unknowingly bought the used car in that condition."
Then go back to the seller. Otherwise, contact the creator of this light organ.
Translated on 12-07-2026, 17:24.
Herbert likes this.
Post16-03-2022, 22:47    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Please request the CodingLog.CSV and AdpLog.CSV files from Verbasteler.
Translated on 12-07-2026, 17:25.
Florian320
2004 Audi Cabriolet
Post17-03-2022, 8:50    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Good morning and thank you very much!
The car was acquired in the usual way.
The customer has now informed me that the Start/Stop function was deactivated using Carly and he would like it to be reactivated. Can you tell me which coding is required for this?
I will definitely let you know if it works out.
Florian.
Florian320
2004 Audi Cabriolet
Post17-03-2022, 18:13    Subject: Decode/remove Pace Car flashing on Golf VII Quote
Okay, I have good news. There was a communication misunderstanding with the customer: it turned out that the issue was only with the "pace car" flashing when using the hazard lights, which is relatively easy to reprogram. The normal turn signal was still activated when turning.
I also immediately activated the Start-Stop system, which isn't a major issue either.
Thank you for your help!
Translated on 12-07-2026, 17:26.
Post18-03-2022, 18:10    Subject: Decode/remove Pace Car flashing on Golf VII Translating...
[Translating...]
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V / Touran Radio rauscodieren Electrical Systems, Vehicle Electronics, Multimedia
No new posts after thermostat change, slower speed and blinking Diesel Engine Technology
No new posts A3: LEDs for alarm system blink as desired. Mood Diesel Engine Technology
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
