Audi V8 D11: Diagnosis Not Possible
Octavia_4x4
Post29-05-2022, 10:44    Subject: Audi V8 D11: Diagnosis Not Possible Quote
Hello, after MANY years, I'm back. I'm having trouble getting my VCDS to connect to my classic car. Is there anything I can optimize in the system settings, perhaps regarding baud rate or other parameters?
Vehicle: Audi V8 D11 3.6, manufactured in 1989.
The vehicle has two OBD-II connectors located in the passenger footwell. The strange thing is, I used to be able to access the ABS system, but now nothing works.
Does anyone have any ideas on how to gain access to the engine control unit (ECU)?
"With my Bosch ESItronic workshop software, I can access everything, so I suspect there's a configuration issue."
Maybe someone among you has some good ideas.
Greetings.
Georg.
Translated on 11-09-2026, 17:04.
Post29-05-2022, 12:03    Subject: Audi V8 D11: Diagnosis Not Possible Quote
It's possible that the quartz crystals in the control units and the diagnostic cable have drifted out of sync.
What kind of diagnostic system do you have?
Take a look at the connection setup in the upper left corner of the control unit information window. You should also be able to see the bitrate there.
Translated on 11-09-2026, 17:05.
dieselschrauber likes this.
Post29-05-2022, 16:07    Subject: Audi V8 D11: Diagnosis Not Possible Quote
Vehicle: Audi V8 D11 3.6, year of manufacture 1989.
The vehicle has the 2x2 OBD connectors in the passenger footwell. The strange thing is, I could at least access the ABS system before. Now, nothing works at all.
Given the vehicle's production year, accessing the Modular Stereo System (MSG) with VCDS (Volkswagen Diagnostic System) was likely not yet possible, so the only option would have been to manually disable it.
What color are the connectors (in the photo)?
Translated on 11-09-2026, 17:07.
Post30-05-2022, 6:13    Subject: Audi V8 D11: Diagnosis Not Possible Quote
Here's another link that might be helpful:
http://www.sjmautotechnik.com/trouble_shooting/ecufv8.html#V8fault
Translated on 11-09-2026, 17:08.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Audi A4 B6 Rear Door Won't Unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A6 4A: No Diagnosis Possible On-Board Diagnostics (OBD)
No new posts VAG-COM Diagnosis for PSA (Citroen): Possible? On-Board Diagnostics (OBD)
No new posts Is it possible to perform a diagnosis on a Peugeot 406? On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
