Audi A6 C8, 2020, Oil change interval accidentally reset
Jackson
Post10-04-2022, 18:08    Subject: Audi A6 C8, 2020, Oil change interval accidentally reset Quote
"In the above-mentioned vehicle, the oil change interval was accidentally reset mid-cycle. How can I manually adjust the remaining mileage/time to the correct value? The system was not set to a fixed interval, but rather a distance-based or time-based interval."
Jackson.
Translated on 09-07-2026, 3:05.
Karma: +647 / -0   Thank you, like it!
dieselschrauber likes this.
Post12-04-2022, 6:02    Subject: Audi A6 C8, 2020, Oil change interval accidentally reset Quote
I would have said that if the service is actually performed and the system is reset, then it should work correctly again.
Karma: +1354 / -0   Thank you, like it!
Post12-04-2022, 8:14    Subject: Audi A6 C8, 2020, Oil change interval accidentally reset Quote
There are several guides and threads on this forum about that. Just search for "service interval".
In your specific case, of course, it's not the entire interval that matters, but rather the kilometers driven since the last service and the number of days that have passed.
Translated on 09-07-2026, 3:06.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts T5 CAAD ash value accidentally set to 0 Diesel Engine Technology
No new posts Ash loading value not reset after DPF replacement On-Board Diagnostics (OBD)
No new posts MicroCAN On-Board Diagnostics (OBD)
No new posts Retrofitting a tow hitch to an Audi A3 8V, production yea... Electrical Systems, Vehicle Electronics, Multimedia
