| đ â đš |
| VW Service Interval Display / Maintenance Indicator | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Bertil |
Resetting the service interval display / maintenance interval display on VW vehicles.
Current vehicles, new VCDS versions: Current versions of VCDS already have a built-in assistant for resetting service intervals, see: Assistant for service delays Control units with diagnostics via UDS require manual resetting of the corresponding channels in the instrument cluster. Service delay via UDS General information regarding service reminders or service interval displays: This article is by Bertil, thank you very much! The service interval setting for VW vehicles. VAG vehicles have been equipped with a service interval display/maintenance interval display for several model generations. It is always located at address 17 within the circuit breaker panel (combination instrument). The + Unfortunately, the reset process is not consistent (at this point, a heartfelt thank you to the developers). what quickly turns it into a complex task. Volkswagen vehicles with fixed service intervals valid for: Polo 6N 1998-2002 Golf4 Passat B5 Lupo -2002 New Beetle Bora Transporter T4 and similar models The inspection data is stored in channels 10, 11, and 12. In control unit 17 (instrument cluster). The individual channels mean the following:
Oil change service every 15000 km , reset channel 10 Inspection every 12 months , reset channels 10 and 11 Inspection service every 30000 km , reset channels 10, 11, and 12 Valid for: VW Sharan, older model , with a fixed service interval . The older Sharan stores its service data in other channels:
Oil change service every 15000 km Reset Channel 05, 06 Inspection every 12 months Reset Channel 05, 06, 07 Inspection service every 30000 km Reset Channel 05, 06, 07, 08 Vehicles with optional fixed / flexible service interval display from model year 1999 / 2000: Valid for: Golf4/5 Passat B5 New Beetle Bora Sharan Transporter T4 and similar models
Resetting the service event:
Bei durchgefĂŒhrtem Long-Life Service muĂ das Fahrzeug laut untenstehender Tabelle an die ĂlqualitĂ€t angepasst werden:
Translated on 07-09-2026, 20:44. |
| Ratings - VW Service Interval Display / Maintenance Indicator | |
Average rating: 4.10 - worst rating: 2 - best rating: 5 - number of ratings: 10 - View ratings |
| đ â đš |
Foren- und Portal-Software: V8.0 © 2003 - 2026 Kaufmann Automotive GmbH & Shop fĂŒr Kfz-DiagnosegerĂ€te. Parse time: 0.053s
